Model G overheats
Alexander View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Topic: Model G overheats
    Posted: 07 Jun 2017 at 4:07pm
I've got two Model G tractors.  Both running.  One of them runs at a normal temperature, but the other one, the subject of this post, seems to run hot.  I topped off the antifreeze/water mix to the overflow spout at the top of the radiator (it had been low).  I ran it for a few minutes, and water began leaking out the overflow spout.  The top tank in the radiator felt quite hot to the touch.  I saw some steam, but not sure exactly where it was coming from.
As I understand it, this model has a "gravity" cooling system, meaning that there is no thermostat.  Cooling fluid heated at the engine comes up out of the cylinder head and up the top tube to the top tank of the radiator.  It then cools at the radiator, and the fluid "falls" through the radiator, emerging at the bottom and returning to the bottom of the engine.  And so on.  I've also read that if the fluid level is too low, it will break the siphon effect and not allow the cooling function.
Seems like a pretty simple system.  I have some questions:
1)  Is it normal for the fluid level to expand during operation as a result of increased temperatures?  If so, what is the correct level to fill the tank to?
2)  If a gravity system like this is overheating, what are the possible causes, and how does one evaluate the situation?
I would appreciate any help or guidance.
Thanks,
Al
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 4:14pm
re:
1)  yes, it expands...I'd fill to just above the 'core' tubes......
2) rad needs to be 'back flushed' or cleaned. some of the vertical tubes are probably plugged at the bottom of the rad( the horizontal 'manifold'). Best to remove rad , do the workaway from the tractor, as it can get messy. When passages are cleared water should freely flow and be clear.  the fins should be firm on the vertical tubes. If not they will not transfer the heat into the air.
while I've owned 3 G's over the years, they're all gone. only one needed the rad backflushed....yuck. it was messy....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 4:21pm
JayB
When backflushing a radiator, how do you do it?  Say I remove the radiator from the tractor, after draining the coolant.  Do you run a garden hose into the bottom tank of the radiator?
Al
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 4:58pm
Top paragraph covers it well, I try to keep mine in the middle of the inlet or higher
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 6:17pm
If I thought the rad had sediment in it, I would first go to your fav auto parts store and buy some radiator flush. Drain the rad, and maybe flush it out a bit with a garden hose. Then add the chemical, and fill to the top of the fins. Operate the engine till fully warmed, maybe let it cool off and do it again.
 There should be easy directions to follow on the bottle. NAPA has such a product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 6:39pm
Thanks for all the replies. Before I get into any of the radiator cleaning methods described I'd like to know approximately what is a normal operating temperature, and how do you measure it? Sounds like the normal operating temperature might be above 212 F?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 6:50pm
I 'm not sure about the G, but most systems like that are not pressurized so , shouldn't run that hot. If you don't have a good oven thermometer to "borrow" get a $30 infrared gun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 7:00pm
Pull the Rad out, bring it to your local Radiator shop and let em' flow test the unit. If its plugged he'll tell ya. They can "rod" out the tubes if they are plugged. Once the tubes are cleared out, they reflow test it again. In most cases, its ready to go. If it plugged so bad they can get it cleaned, it may need to be recored...  HTH
Steve@B&B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 8:11pm
Check the timing and the fuel mixture. Late timing or a lean mixture will make any gas engine run warm.
The standard half and half permanent antifreeze mixture boils at about 225 F at atmospheric pressure, higher with a pressurized system depending on the pressure.
Even with the gravity flow system there should be a thermostat otherwise it won't ever warm up and an engine stuck at less than 135 will not be efficient because of the loss of heat energy from combustion to the cold block and head.
I have G owner's manual and a multi tractor shop manual that includes the G on line at:http://www.geraldj.networkiowa.com/Trees/
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 10:29pm
G's do not use thermostats of any type, they heat up just fine in a short time, if the water level is right and the fan belt isn't slipping it maintains quite well. I've shot mine a few times with the infrared thermometer after plowing pretty hard and never recall it being over about 180
Ford 345C TLB
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 10:43pm
We fill ours to the top of the radiator fill. If you don't keep it filled the water will not circulate and engine will overheat. If the radiator is full and it still overheats (assuming fan is working) then the system needs to be flushed.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 10:04am
All that the Continental N62 Instruction Manual has to say about the cooling system.
Gerald J.
jange01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jange01 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 12:01pm
I second Gerald J's advice. Check your timing. Retarded or late timing will definitely cause an engine to run hot. Just had a Farmall Cub in the shop that would overheat in less than 10 minutes of starting. Customer said he's seen the manifold glow red. Timing was too late (retarded). Was set at about 5 degrees After Top Dead Center at high rpm. Should have been 16 degrees BTDC at high rpm.
When timing is too late, the exhaust valves may / are starting to open when combustion occurs. This heat is way too much to put out of the manifold at running rpms. The gases don't get a chance to cool down after combustion by the decompression of the cylinder pressures. It causes the entire engine to get way hot and the cooling system (especially a thermal siphon system) can't keep up with it.
Of course, as others have said, you need to have a good operating cooling system also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 5:06pm
Thanks again for the great replies and advice. I will check the timing on the G that I have. I will also check at what temperature it runs, and will also check to see that there are no thermostats in the system. I will report back, but it may be several days before I do so. Thanks again!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 10:28pm
Just clarification- The radiator cap IS a pressure-type cap. Not very high pressure, but just a few PSI is sufficient to do the job.
These are called 'passive' cooling systems, because they don't have a forced circulation system... instead, they use gravity and density to cause circulation. There are two types of gravity/density cooking circulation systems- there's Evaporation/Condensation, and Thermosyphon. Understanding them, makes it much easier to solve cooling system problems for 'passive' cooling systems.
Evap/Condensing early- it's also referred to as 'hopper' cooling... and it's very simple, and you'll see it on hit-and-miss and throttle governed slow-speed engines. The engine block and head are encased with a cooling jacket, and there's a hopper or tank above the cylinder. As the engine warms, heat is conducted into the cooling water, which evaporates off (where block contact surface is below boiling) or it boils off (cylinder/head areas are above boiling). Regardless of what happens, as long as there's sufficient water in the hopper, the engine will NEVER get over 212F at sea level, or over 193F at 10,000ft.
The open hopper is considered 'total loss' cooling, because the cooling medium (water) is allowed to either evaporate or boil off. Recovery requires just putting more water back in the hopper.
An enclosed 'radiator' can also be used, so that any water that boils off, rises up the radiator's cooling fins, and since there's airflow over the cooling fins, heat passes out, and the steam condenses, precipitating back down into the hopper below.
The third type, 'active' cooling systems... use a pump to circulate.
Of course, the flow character of each system are entirely different... the passive system must have low restriction to flow, and it must be such that steam bubbles naturally want to pass uphill through the plumbing. Hot cooling liquid needs to want to flow too, so blocks designed for thermosyphon have lots of available space in the jacket for good flow... or at least, we hope they do... it may be plugged a bit.
In a coolant-pump -based system, the flow restriction is not nearly as critical, and in some ways, having some restriction (and that pressure cap) means the centrifugal pump has a little more head-pressure, and as a result, high temperature areas are less likely to boil... so it absorbs more heat, and sheds it quicker at the radiator.
IF you pull the radiator to flush, I recommend you pull the coolant neck(s) from the engine, pull the cylinder head, and flush the block out really good, shove a rod down through every passage of the block and the head, then blast water through it every which way you can. Having a clear radiator is important, but having a clear flowing block, and one that isn't insulated by large deposits of crud, is absolutely positively mandatory.
This page was generated in 0.131 seconds.
