HD5G Shifter Repair
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: HD5G Shifter Repair
    Posted: 10 Mar 2022 at 8:13am
I installed the repaired shifter last week, it sure works smooth and tight now Smile
I brazed the holes up solid and drilled new holes to be a slip fit for the 3/8" roll pin. The center piece was hopelessly worn out so I made a new one and drilled it for a tight fit on the roll pin.
The side support bolts were quite worn so I built them up with brazing rod, then hand-filed them to a nice sliding fit. This took a couple of hours per bolt, but lacking access to a lathe now that I am retired I took the cheap way out Big smile
I expect this to outlast me.Tongue
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 11:48am
hope your roll pin works , I used a piece or drill rod for cross pin - then made bolts on lathe and ground a relief in drill rod for end of bolts to index into to retain the rod .
  Then whatever works is better than a worn unit .
clark66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clark66 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2022 at 8:13pm
Thank you for posting these pictures. I would like to make this repair sometime soon on a HD5G that I acquired last fall. The shifter is completely loose and very hard to get in gear.
Was also taking a closer look at the bushing wear on track and was curious if anyone could give their opinion on how much is left on this bushing before it gets to exposing the pin?
It seems like at least a good 1/8 inch or more  of material has worn away- I would imagine that they should be at least turned soon-
 before its too late.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2022 at 10:10pm
It's to the point DO IT NOW before it wears through .
There are a couple other posts on repairs to the shifter on this site .
Post Options Post Options   Thanks (0) Thanks(0)   Quote clark66 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 12:31pm
Found the other posts related to the gear shifter repairs, ThanksThumbs Up
Does anyone happen to know any outfits that do track press work that would turn the pins and bushings in the Philadelphia/ Eastern PA /S. Jersey area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 4:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 8:52am
I thoroughly researched every post I could find on the shifter repair, then came up with a plan that fit my budget and needs (read that as looooooow budget and simple needs). A lathe would have certainly made the project quicker and easier, but probably not much more precise (I do have some experience with precision hand fitting of metal parts).
My main concern is about longevity due to future wear at the interface of the new brass portion bearing upon the roll pin. I did position the roll pin with the smooth portion facing upward so as to have the weight of the shifter bearing on the largest surface area, and I did hand-pack the entire area with grease. So long as the roll pin does not break I do believe it will last longer than I will need it, and my grandson did observe the whole process, so he should be capable of completing the repair next time Wink
Your pins/bushings need to be turned RIGHT NOW! Do not pass Go, do not collect $200
Post Options Post Options   Thanks (0) Thanks(0)   Quote clark66 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 5:00pm
Right!  looks like there right on the edge of wearing through, Thanks for the links to the shops- Its a shame they weren't turned before, it looks like the sprockets and pads barely have any wear and seem to have been replaced somewhat recently.
This page was generated in 0.146 seconds.
