Newbie Question
dark_knight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dark_knight Quote  Post ReplyReply Direct Link To This Post Topic: Newbie Question
    Posted: 13 Oct 2025 at 6:32pm
Hi.  I am looking a purchasing a CA with loader.  The loader has long manure forks attached to the bucket.  However, I am more likely to use the tractor for moving dirt and gravel.
I've tried searching for a plate or adapter to cover the forks somehow and allow the bucket to be used for materials, but I can't seem to find such a thing.  It looks like there is something similar to what I need in the third image on this page, https://forums.yesterdaystractors.com/threads/what-loader-are-these-for.1755672/ but the poster provided no info, or even the name of such a device!
Is there a decent solution for this problem, or should I look elsewhere for a loader with a different bucket.
Many thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2025 at 7:05pm
Post a picture of your loader bucket, will make things a lot clearer.  1 solution us to just get a proper dirt bucket for your loader.  Another would be to leave the forks on and have a welder fab up a removable plate that covers most of the tines, leaving just a few inches of the tips exposed at teeth.
Welcome to the forum...Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote dark_knight Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2025 at 7:24pm
Good idea!  Thanks for the reply!  Here is the image.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 6:38am
50 years ago you could of bought my fathers CA as it had the loader with plate as you describe! It was a plate of steel with holes for the forks to go thru. It was AC Stock.
It shouldn't be difficult to fabricate one. Though I recall my father never took it off as a slight bending of the forks made it difficult to be "easy on- easy off".
Edited by Stan R - 14 Oct 2025 at 6:40am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 6:41am
That bucket is not an original Allis CA loader bucket, a Model 8.
Allis had a 'Dirt Plate' available that slid over the Tines to create a Dirt Bucket.
There was also a Snow Bucket available that included a longer bottom Plate and also Plate Sides.
G
https://www.ebay.com/itm/326199764948
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 8:03am
i would not bother trying to make it removable.. Just get the local weld shop to lay a 3/16 inch steel plate on the forks and weld in place... probable a wing on each end.. Not difficult at all.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 10:52am
find an old bucket of choice and run the forks thru the back and secure per your preference for permanent or removal...if you lived in the neighborhood, I'd give you one...
Dale
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 2:31pm
It looks like you bought a narrow front end tractor.  Not great for moving dirt and gravel.  With a bucket full of material, it's going to make for an unstable load.  Trying to steer would also be a challenge as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dark_knight Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 3:52pm
Thanks for everyone's input!  I have not purchased yet, so this is fantastic info.
I had not considered the stability with the narrow front end.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 9:37pm
I agree with the narrow front being dangerous with a loader. To me they feel pretty dangerous without a loader. Think of a tricycle with a fat kid standing on both sides of the front tire
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 7:19am
well I suppose narrow front is not ideal for a loader, but that’s exactly what I learned on. I was doing loader work with a narrow front before I was a teen. Depends on what you’re using it for. I wouldn’t recommend going into the woods carrying logs up a creek bank, at least not until you have lots of experience. But around a yard, in the barn, stuff like that it’s doable. Low and slow is the mantra.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 9:14am
For a tractor that size, and vintage I personally would avoid using for digging dirt and gravel. Those loaders were designed primarily for loading manure, either from a barnyard or manure piled from winter.
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 9:50am
The mounting of loader on a CA is less than ideal. I have seen many photos of CA's that were broken at the bell housing because of too much strain put on the loader. I have a CA with a Model 8 loader and they are fine if you take into account the limitations of the equipment. That being said, from the picture you posted the loader has been modified to give hydraulic tilt. The bucket could have a plate made to slip over the forks. Can't tell from the picture but it appears to be a modified Model 100 loader. I wouldn't try to dig with it but for light jobs it would be fine.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
This page was generated in 0.075 seconds.
