WD45 Radiator |
   TomYaz
      Quote   Reply
     Topic: WD45 RadiatorPosted: 07 May 2018 at 7:47pm  |
   So I got a new clancy radiator for the 45.  Did a dry fit and as fully expected as nothing is ever easy, the fan blades do not clear the radiator...I do hope what is pictured below is about dialing in or out the fan blade to make it clear.  Of course that is frozen up too...
   wfmurray
   Joined: 13 Sep 2009 Location: Bostic NC Points: 1225  |
      Quote   Reply
     Posted: 07 May 2018 at 7:59pm |
   Adj at pulley only adjust the pulley .Not to sure but i think fan blade is on reversed.
   Brian Jasper co. Ia
   Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508  |
      Quote   Reply
     Posted: 07 May 2018 at 8:05pm |
That adjustment is for the width of the sheave only. Looks to me that your fan is on backwards. You might try flipping it around and see how it fits.
   TomYaz
      Quote   Reply
     Posted: 07 May 2018 at 8:22pm |
   Hmm.....on backwards?  Would that push the air the wrong way?
   Allis dave
   Joined: 10 May 2012 Location: Northern IN Points: 3074  |
      Quote   Reply
     Posted: 08 May 2018 at 6:58am |
My 45 has a 5 blade fan. It wouldn't clear my new radiator shroud. I had to grind a little on the blades.
   Brian Jasper co. Ia
      Quote   Reply
     Posted: 08 May 2018 at 7:57am |
Not only when you reverse the blades, you turn it the other way so it still moves air, just not as efficiently. Look at the blades. They should look somewhat concaved away from the radiator. Sort of like this. l (
   TomYaz
      Quote   Reply
     Posted: 08 May 2018 at 11:54am |
   I see,,,
  Well if I meet my Dad in the next life, will ask him whaddup with dat!? But perhaps it came from the factory that way....afterall he did find ball bearings in the oil pan...also the old radiator had the corner braces torn...or bent out....thats an indicator things werent right.. Thanks for the info guys.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
