wd 45 engine removal
chris502 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 engine removal
    Posted: 22 Dec 2011 at 3:59pm
We are trying to remove the engine from a wd 45 we have everything ready to come out but it will not come out fully. We think that there is something holding the clutch plate on the shaft but we cannot visibly see anything holding it. Any info would be appreciated and I checked another thread but no help on our problem.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 4:11pm
rust? if water and oxygen ever got down there that would do it
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 4:24pm
Have you removed the front angle motor mount and the steering shaft from the u joint?
If you think the clutch disc is what's holding it up, you can remove the pressure plate bolts from the bottom hole in the clutch housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 4:40pm
yes we have the motor suspended and we have also taken the pressure plate out it is moving back and forth on this shaft but it is hitting something like a pin or key. Does the shaft come out with the engine or does it stay in the transmission?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 4:47pm
pretty sure the shaft stays
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 5:02pm
we can rock the motor back and forth pretty far but just won't go the rest of the way. The heads and the oil pan are off so we have a pretty good view of everything.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 5:21pm
What about the hand crank shaft that goes thru the front end?
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 5:26pm
yea i've got the crank vise gripped out of the way.
AC Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 6:37pm
It shouldn't have a pilot bearing. Was the tractor running before you tore the engine down. Not likely but maybe the clutch disk pressure plate flywheel and imput shaft all rusted together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 7:16pm
Yes WD45's have a pilot bearing, The input shaft can hang up in the pilot bearing and some of them have a bushing on the end of shaft too and they are bad about rusting to the shaft and bearing too.
Don
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 8:08pm
you cant have the motor raised much at all in the front or you will hang on the transmission input shaft .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 9:15pm
Do you have the dust cover off of the bottom of the bellhousing?   I'm sure you probably do but I know from reading on here it has been missed a time or two.   And yes, you can't put alot of up pressure on the engine, just enough to take the weight off and to move it forward.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 9:39pm
Did you unhook the throttle linkage and choke linkage? What about the bolt behind the air cleaner? How far will it move back and forth?  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 10:24pm
So how are you supposed to remove the pilot bearing or are we just gonna have to force it off. And yes we have the throttle and choke linkage off and the dust cover so it has to be something inside the clutch plate area. We can push the motor far enough to one side you can almost see the other side of the clutch plate but it is not coming any further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 10:30pm
oh yeah the tractor was not running my dad bought it locked up hoping to get it freed up. That didn't work so he found a trike that ran for a good price so that's what's going on with the whole situation. He did successfully free a d-15 so  that was why he invested in it to try.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 7:20am
502 you didn't say how far the engine moves forward, the trans input shaft stays with the trans and as said with all the trouble you are having take all the preasure plate bolts out from underneeth . If you are sure there is no interferance with any hardware it must be pilot bearing. Also as said engine must come sraight forward about 4 or 6 in. before tilting upward.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 12:15pm
one more thing that could cause a fubar is the starter if it was left in the bell housing before attempting engine removal
Edited by mlpankey - 23 Dec 2011 at 12:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 3:47pm
Well guys we got it out, it took a little coaxing with a pry bar but it's out. Thanks everyone for your help and have a merry christmas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 4:12pm
So --- what as holding it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 7:00pm
Yeah, WHAT was holding it in Chris?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 4:53am
Had the same problem when I rebuilt my D17,was really hard to get apart,input shaft splines were stuck in the clutch disc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris502 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 7:52pm
I think the flywheel was froze to the pilot bearing on the end of the shaft. The more we moved the whole engine around the looser it got. I took someone's advise and started taking the screws out of the clutch plate, then the very last one was all the way on top and did not allow room for anything we had. Out of frustration we started prying the engine outward and wiggling it some more the whole engine came all the way out. So we are gonna start taking out the good motor hopefully this week.
This page was generated in 0.099 seconds.
