K2 grain header |
Burl ![]() Silver Level Access ![]() Joined: 13 Sep 2014 Location: Aurora Mo. Points: 232 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Aug 2016 at 5:16pm |
I need to pick up and haul 13ft. header off a K2. What are the proper lift points on it so I dont bend or fold any parts ? They have a loader tractor on their place and my trailer is prob. 30 in high. Chains , straps. rope???
Thanks for help !! |
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
You should be able to put the bottom of the bucket under the lower latches and wrap a chain around the top of the throat opening. I have moved them that way before without damage
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Thanks Dan , sounds like that would work fine . I wonder what a 13ft. header weights?
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3574 |
Whether it has a series II wobble box flex sickle or a pitman arm drive with a hart/carter add-on fllex sickle, it will weigh more than a standard pitman rigid sickle. Without viewing my gleaner platform operators manual, I'm guessing 1500lbs for a rigid??
Thank you , it is a std. pitman rigid. I was guessing under a ton but really had no idea. thanks again!
I had one on an F2 manual said 1839lbs.
Edited by Dans 7080 - 02 Aug 2016 at 9:01pm |
shameless (ne) ![]() Orange Level ![]() ![]() Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
I pick up and move all my heads (Gleaner) & (IH) with my ag crane, I just wrap a chain around/thru the throat opening and lift. be careful if there are any hyd steel lines attached there so you don't crush them.
