D10 Series 2 Ignition Switch Washer
KD8NGV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Topic: D10 Series 2 Ignition Switch Washer
    Posted: 18 May 2023 at 9:54am
Trying to get my 1961 Series 2 D10 ready to take to the New York GOTO.  Need to get a new Ignition Switch.  The book calls for part number 70235785.  If you go to DJs Tractors they have this style of switch, but here is the kicker, in the description it says:  "Up to SN: 3500, it will also fit the later serial numbers, but you must use 70227195 washer so switch will fit the dash (this washer is not available through DJS Tractor Parts)."
My tractor serial number is 41XX.
I can't find a picture of this washer, nor a place that has it for sale.  What is the need for it? Can I use another washer of a certain diameter?  Do I even need it?
Alvin M View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 12:55pm
AGCO has that washer 70227195 0.31
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 1:16pm
I often wonder why folks don't try AGCO first
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 2:37pm
I appreciate the response.  AGCO Parts online shows no stock when I looked (2nd place I looked, 1st was my parts book). I'll call some of the dealers around and see what they may have.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 2:58pm
I'm not looking in the parts book right now, however the early D10/12 tractors used the Delco switch during production. This is the funny looking key that was also used on Oliver's for many years. I'm guessing that you are trying to retrofit the newer INDAK switch into a tractor that should have the Delco switch. Use the Delco switch and no adapter washer needed.
The Delco switch is available from Brillman.com  Part Number B5003-005 Currently $39.95. I may cost a few bucks more than the Indak switch. Because it is a better quality switch.
Edited by PaulB - 18 May 2023 at 3:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 12:38am
Paul what’s the allis part number for that switch.
Is this the washer 227195
Edited by Mikez - 19 May 2023 at 12:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 6:33am
I think the Allis number for the DELCO switch should be 231705.   The washer to use the INDAK switch in early tractor should be 230243
This page was generated in 0.143 seconds.
