AC 400 and 500 loaders? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10823 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Aug 2025 at 9:54pm |
Has anyone ever made a bracket to pin cylinder rods and loader arms to, that mimics the loader bucket bracket with hook and pin to hold loader bucket? I want to remove bucket when not using it, but be able to attach it easily. Any help appreciated. Tracy
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1938 |
I made a set for my Dual loader on my 200. They move the bucket about 6 inches forward. If I did it again I think I could get a little closer. I made them to switch between the bucket and bale forks. The top hole is cut open to the top like a quick hitch and I just leave the pins in the bucket and hook it and pick it up then put the bottom pin in to secure it. I welded some stop in so the pins always line up. I made them out of 1/2 inch plate. I have hooked a chain in them to pick things uand even with the bucket off you can push things with them on if you need to.
Edited by DanWi - 26 Aug 2025 at 10:44pm |
Dan, that sounds like what i need. Sent you a PM. Thanks, Tracy
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1491 |
![]() ![]() Edited by orangereborn - 27 Aug 2025 at 3:51pm |
