Allis Chalmers I 60 rough terrain forklift shuttle
George anderegg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George anderegg Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers I 60 rough terrain forklift shuttle
    Posted: 05 Jul 2024 at 10:00am
Hi Allis Chalmers collectors I'm in need of a shuttle clutch rebuild kit for Allis Chalmers i60 rough terrain forklift I have no serial number or anything I have been looking for the last 6 days and have found nothing can anyone help me
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 11:54am
You can also try Herc-U-Lift in MN as they were a AC equipment dealer for Industrial equipment .
 Minn-Par in MN (online only) might have some items also .
Looking for replacement parts for your Allis Chalmers forklift? Our online catalog lookup makes finding the right part easy.
Missing: i60 ‎| Show results with: i60
Allis Chalmers I60 found in: Manifold Gasket, Allis Chalmers D14, D15 series I, I60, I600, Manifold, Allis Chalmers D14, D15 series I, I60, I600, 70228184, ...
5.0
store rating
 (12) · ‎2–5 day delivery · ‎90-day returns
Missing: terrain ‎| Show results with: terrain
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 6:38am
Wouldn't the clutch pack parts be the same as for the Power Director clutches? I know the gearing is different between the two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 9:33am
dimensions bottom of page....
Edited by steve(ill) - 06 Jul 2024 at 9:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 9:37am
disassembly view  ???
Edited by steve(ill) - 06 Jul 2024 at 9:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote George anderegg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 6:58am
thank you so much
Post Options Post Options   Thanks (0) Thanks(0)   Quote George anderegg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2024 at 3:55pm
I'm having trouble adjusting this shuttle clutch I followed the video and still can't get it to specs
Post Options Post Options   Thanks (0) Thanks(0)   Quote George anderegg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 8:59am
Does anyone know where I can locate new parts for power director
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 9:15am
you might send Matt an e-mail and see if he has anything.. or maybe knows someone who does... Just a State over from you..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 5:30pm
There are THREE stations of shims on those clutches. At each station there are THREE shim packs: forward--neutral--reverse......The neutral shims are LONGER than the forward and reverse shims. The total thickness of all three shim stacks added up is .205" . This .205" number must be maintained !!!! When you remove short shims, you must replace a short shim with a long shim into the center (neutral) location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote George anderegg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 7:13pm
Thank you doc I'm using used parts and the center discs that separate the high and low are worn does that affect the adjustment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 8:14pm
Removing the short shims (as needed) is to make up for any wear on the discs, separator plates or the center plates. The center plates get grooves worn into them. Doesn't mean they are junk, that's just the way they look when they are old. When you run out of short shims and the hand lever loses its "snap", the clutch is worn out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote George anderegg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 8:20pm
Thank you for the tip have a blessed day to you and those around you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 8:24pm
Always remember the three shim stacks MUST add up to .205". If you removed a .020" short shim, you MUST replace it with a .020" LONG shim in the center. You cannot use short shims in the center location.       EDIT: In your case, you could use short shims in the center ONLY to establish where your shims need to be. Once you've figured that out go to your AGCO dealer and replace any short shims in the center with the same thickness LONG shims.
Edited by DrAllis - 13 Jul 2024 at 8:46pm
This page was generated in 0.106 seconds.
