Mechanical lift on plows
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: Mechanical lift on plows
    Posted: 19 May 2020 at 11:40am
I have a 3 and 4 bottom mechanical lift plows that are not completing the lift process.  They go part way and then stop, is there any lubrication that can be done so they work smoothly.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2020 at 1:09pm
If they are old I would disassemble and clean out the old grease, then put together and grease appropriately.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2020 at 1:19pm
YUP, tale them apart and free up the clutch arms and grease everything in there ---- these are picky bout being free and lubed to work right.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2020 at 1:25pm
I'll bet that there is too much grease inside the assembly.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2020 at 5:41pm
The cog and roller is not working properly inside the clutch wheel. Take it apart and clean out the hard grease, dirt, mud wasp nests, and other crud. Re-grease when put back together.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
