433I valve cover bolts |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Sep 2022 at 8:36pm |
I am changing the valve cover gasket on my 6080 and noticed the previous owner had oversized nuts as spacers over the shoulders of the bolts. The parts book appears to show a stack of flat washers as spacers. What is the reason for this and is there anything special about them. Can I use ordinary flat washers instead? Many thanks!
They have to have the correct number of spring washers or it will tighten down too tight or too loose. If I remember correctly it is seven spring washers. MACK
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 627 |
It should be a shouder
bolt so it wont tighten too tight. Ive never seen one leak with that shoulder bolt and spring washer kit |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8641 |
They are NOT flat washers.They are kinda "w" shaped. I was thinking they face each other every other one. It's what's on 8000 series 426's.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21939 |
They were shaped like a disc blade. Every other one was stacked and it was like a spring.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4092 |
They sound like 'bellevill' (sp) washers, which are a form of spring.
Bellville washers. Seven of them taped together to make them as one. Trouble is with time and heat the tape deteriorates and then you have seven individual parts laying in a pile.
Sooo....positioning is...with bolt in position, bottom one facing down against cover then next pair facing each other then repeat again for the 2 pair left? Only trying logic. How'd I do?
BINGO !!! We have a winner.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87966 |
wonder why they didnt use a thick rubber washer ?
Many thanks! Going to try ordering them from AGCO tomorrow. Hoping they are still available.
I'd say because the washer setup would last longer....My 220 just has Phillips head screws through the gasket. Old school it is but has never been a problem in over 30 yrs.
Pt #74036977 still listed with a price so must be available? $55.87....wonder if that's per fastener? Doesn't say. Call a dealer.They can find out.
Might be a whole "kit" for one engine.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8707 |
Just the washer stack #74036973
