Which plug is the oil level...pic
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: Which plug is the oil level...pic
    Posted: 21 Sep 2022 at 11:06am
I'm working on a F700 and I'm changing the oil.
It has three drain /fill plugs. (bottom, mid bottom, top)
Which is the correct fill level plug?   Top or middle plug?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 11:08am
The bottom plug is not shown.
Edited by Ron(AB) - 21 Sep 2022 at 11:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 11:23am
The housing cover was used on several differing styles differentials, it is for a Temperature Sensor in some applications and plugged here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 11:35am
So the top plug is the fill level?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 11:43am
Yes.
General rule is somewhere just below Axle Tube center, so the bearings receive adequate oil for lube and cooling.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 8:08pm
The 1/2 " square on top as Miller said. Not the smaller 3/8" square. Not sure why they have that smaller one. Too low to be a minimum level. Has to be close to the half on the housing.Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 8:13pm
Hopefully you can get the bottom drain out. Have seen those scrapped almost flat on dump trucks. If that one gives you trouble heat it up good with torch. Walk away from it and let it cool totally. Then it will come out easy.
