what weight oil for G?
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Topic: what weight oil for G?
    Posted: 30 Jan 2012 at 7:41am
like the topic says.. What weight oil for the engine and what weight for the tranny?
Thanks
Jonathan
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 9:53am
The manual would say 30 for summer, 10 for winter, non detergent. Because that's what they had. Today a good 10W30 will be better year round and keep the engine cleaner inside. If it has only had non detergent, it may need a couple short time oil changes to remove most of the sludge characteristic on non detergent oil. Besides detergent, modern oils have anti corrosion additives the help preserve the bearing inserts. That's for the engine. I don't know what the driveline expected.
Gerald J.
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 10:12am
Manual says SAE 20W. I've been using good quality hydraulic oil in both of my G's for years without problems. Don't forget to drain both holes on the tranny/hyd. housing.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 10:23am
So, if you put in SAE 30W, and it was winter, the oil pressure would be high then?
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 10:26am
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 12:16pm
A 30 weight (there is no 30w) in the winter would make for higher oil pressure--------if you can get it to crank fast enough to start.  It would also make for slow lubrication to the bearings and cam.
As another pointed out, there weren't multi-weight oils back in the 40's or early 50's.
Depending on starting temps and condition of the engine, I would use Mobil 1 15w-50 for temps above 20 degrees and if the engine was a little worn.  For starting at temps below about 20 degrees (or an engine in good condition), I would use their Turbo Diesel 5w-40 oil (it is also rated for gas engine use).
With either of these oils and 100-200 hours per year use, you would only need to change once a year and have good starting and quick lubrication, but a heavier viscosity at operating temps.  The heavier viscosity would help out with a worn engine and oil burning.
As for the hydraulics, most any ISO 32 rated oil should be fine.
Edited by 427435 - 30 Jan 2012 at 12:17pm
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
