Paint Gun
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Paint Gun
    Posted: 08 Oct 2011 at 10:11am
Gravity fed Farmhand gun was clogged so I ran 1/2 gallon of gas through it to unclog it, just tore it apart to hit the seals with WD40 to keep the gas from rotting them. What can I run through it to rinse everything out without hurting the paint I want to shoot tonight? Water?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:32am
Lacquer thinner. I only use lacquer thinner and leave some in the gun inbetween painting days on a project. It evaporates very quickly after the gun is sprayed empty and is not a problem. When I get a gun out I always spray some lacquer thinner thru it before putting paint in the cup.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:33am
Lacquer thinner.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:34am
Course somthing I'll need to ve 18 to buy. Looks like I won't be painting this week.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:35am
If I didn't have to look up how to spell lacquer I would have beat Dick.  LOL
1968 one-seventy
1956 F40 Ferguson
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 11:28am
I always take mine apart and clean everything with thinner and a soft tooth brush. Put it back together and run thinner through it about a minute. After it sets I run thinner through it again before I paint. This system is working good so far. I painted my neighbor's D14 with it and had great results cleaning the gun like this since I didn't paint all the tractor at once. Its just a ole cheapy Trades Pro gravity feed gun from Tractor Supply. It lays down the paint smooth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 11:45am
CAn I safely run water through it to rince it out?
German Shepherd dad
#WD234847
#WD88193
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 12:14pm
Water wont flush out oil based paint.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 12:19pm
never knew there was a minimum age to buy laquer thinner!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 12:43pm
that makes two of us. could be in michigan i guess . just another reason not to live there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 2:32pm
Thanks to Granholm you need to be 18 to buy anything with any chemical you can get high from.
German Shepherd dad
#WD234847
#WD88193
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 4:13pm
Have someone else buy the LT I wouldn't use water in my gun, NO WAY !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 4:35pm
I spell it like it sounds and then the spell check(Mozilla Firefox) underlines the misspelled words in red. You right click on the misspelled word and it gives you the choices of properly spelled words. LOL
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 5:47pm
Even when I buy brake cleaner and carb cleaner at the local WallMart their computer queries about my age.
I always joke with them by saying i am buying the stuff with my social security money.
By the way the advice you got on not putting water in the paint gun is rock solid.  That will make a huge el messo.
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 9:23pm
Dave - You problem is Wal-Mart.
The joy is in the journey.
AC "B" and "WD" and "C"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 9:37pm
I have a Harbor Freight special HVLP that I've been using gas to clean. After I'm done spraying I flush it with gas. Out in the open of course where the mist can't set anything on fire...
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 9:56pm
Lacquer thinner will cut any paint but latex. Minimum requiremnt is to use the same thinner/gun cleaner as the paint company recommends that you thin the paint with.
You can also buy "gun cleaner" I'm with Dick on cleaning/maintaining my guns. Bob
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:20pm
I use laquer thinner or gas in a pinch. About anything in a spray can and most solvents you must be 18 to buy in IL.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 3:39pm
I'll bet you could get real high on gasoline too, and they will gladly sell that to someone under 18! Amazing some of the laws that are put into place to protect ourselves from ourselves.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 4:46pm
Lacquer thinnner will loosen dried latex paint. I put paint thinner in my guns keeps them wet inside and lubed up. Use the thinner that is recommended for your paint! Just my opinion.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 10:24am
Can you buy mineral spirits?  That will work although it is not as aggrressive as LT.
