200???? |
smallfarmer83 ![]() Silver Level ![]() Joined: 21 Feb 2012 Location: Indiana Points: 56 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Apr 2012 at 7:58pm |
Got a 1973 200 a couple weeks ago. Was working on changing all the fluids today oil, fuel filter, water separator etc. My question is were is the fill For the hydraulic fluid, rear end and tranny. And were do I fill the finals at. Im thinking they might be under the floor panels. I located the drain plugs. Is there anything else I need to check before I start using the ol girl. Also does any one know where I can located a good service manual. TIA.
CBL95 ![]() Silver Level ![]() Joined: 18 Apr 2011 Location: Winslow, IN Points: 130 |
I know on ours the hy-tran fill and dipstick is under the cover right underneath the seat the is 2 nuts just take them off and you will see the dipstick
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Thats right they are under the seat , floorboards ; the one one the left , as you are setting in the seat , unscrews with threads and thats the hydraulic system , the other has tabs just turn it and it will be for the transmission etc ,shouldnt say floorboards i guess , its a cover that is on the dipsticks
Edited by DougG - 08 Apr 2012 at 4:20am |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Finals are filled through a plug in the side of each final drive. I use a hand crank pump and fill til it runs out the plug.
Wink I am a Russian Bot |
