Off color air condition question |
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1030 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jun 2022 at 9:44am |
Friend has a MF 4243 cab tractor and he thinks it needs some freon added. This tractor was made from 1998 thru 2001. Does anyone know what year tractors came with R134A freon? Thanks for any help.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
If was 134 factory it will have 134 fittings. If it has 134 adapters on 12 ports its been switched. It is possible to charge 134 through 12 fittings if you the right pieces.
ac45dave ![]() Orange Level Access ![]() ![]() Joined: 23 May 2015 Location: SE(IN) Points: 1346 |
Steve, that should be 134a.It became the standard in the mid 90s.
...I didn't stick the "R" in there either....picky,picky
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87843 |
as Steve mentioned......... R12 are SCREW on fittings... R134a is Quick Disconnect
Edited by steve(ill) - 08 Jun 2022 at 1:51pm |
