D-10 Traction Booster ? |
Nathan ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: ohio Points: 378 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Mar 2012 at 7:20pm |
I know the traction booster setup was standard on the later D-10 but was it an option or even available for the early D-10? thanks nathan
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
Anybody?
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
Traction booster was standard on all early D-10/12's with the high pressure hydraulic system (same as CA). If the tractors were equipped with the optional low pressure hydraulic system with the little tank by the distributer and the pump below the distributer, there was no traction booster. These tractors will also have larger diameter lift cylinders. This will apply to D-10's prior to serial 3500 and D-12's proir to serial 3000.
Edited by Calvin Schmidt - 05 Mar 2012 at 6:13pm |
Thank you calvin
What was the purpose of the low pressure system? thanks nathan
Edited by Nathan - 05 Mar 2012 at 6:24pm |
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
The pump is driven off the cam gear; same location as the P/S pump for the D14 and D15 tractors. The hi pressure pump was the same as found on the CAs and located off the rear pumpkin and driven off the pto shaft. Would guess that the low pressure pumps for the engine mounted location were more readily available at the time.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
The low pressure system was used on tractors mainly used for row cultivating and operations other than plowing. It was live so didn't stop when the clutch was pushed in.
