Local pulls and rules?? |
Guests ![]() Guest Group ![]() |
![]() ![]() ![]() ![]() ![]() Posted: 08 Mar 2012 at 7:59am |
I noticed we had a couple threads that touched on this a bit, but I was wondering how some of you had fared with the rules and things of your local pulls. I have one real close to me each year that is supposed to be separated by plow class, unfortunetely the organizers seem to think a b was a full two plow tractor and a straight wd is a 3-4 class, so it gets to run with 450 farmalls and 720 Jd according to them. I really wish we would go to a weigh in formula and see what happens. I have mentioned it but the JD and Farmall guys won't have it. All the other brand folk MM, AC, MH,etc would love it. How does your respective organizers handle things, I am curious. Love my AC's as I do we just can't seem to put a good showing at the pulls the way they are now and it goes the same for many of my neighbors and friends who run Allis in these type of pulls. Thoughts???? Thanks in advance for your time |
Gary in da UP ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Tractor weight, tire size , and a speed limit level the playing field.
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Nick So. IN. ![]() Silver Level ![]() ![]() Joined: 16 Nov 2009 Location: Indiana Points: 72 |
One thing we've decided is if there are no rules, no one can cheat. For farmstock around here it's 3000 rpm, 20.8 non cut tires, and a speed limit if its a speed limit class. These rules are easy to monitor. It's the same result if we had lots of rules: The guy that spends the most money wins, with the exception of the MPH classes. I assume you're talking about antique classes but just my 2 cents.
I forgot to mention that obviously there are weight classes. |
EricSWPA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: PA Points: 292 |
Are club runs 3 classes a b and c a is first gear only cant pull below shiping weight stock rpms and tire size is limited for each weight 16" drawbar
B division is 10% over rpm 18"drawbar 3mph and up to a 16.9 38 for any weight no cuts in either a or b And c div 20% over rpm 10 mph and 18.4 38 20 drawbar So basically we have a class for anyone to be competitive |
ALLISMAN32 ![]() Bronze Level ![]() ![]() Joined: 13 Mar 2011 Location: Hillsboro, IN Points: 199 |
Ok, oldorangeiron put one of the heavy casting 45 frontends on your wd and fill the front and rear tires with water, you can buy a adapter valve that fits a garden hose and screws onto your valve stem.Put a 45 crank in the thing leave the WD pistons try to find a 175 camshaft or get yours reground. Install a 175 governor spring and get that thing cranking some rpm's. Put the later non wd or wc manifold on it if not already on there. Some 14.9 or 16.9 28's will help too air pressure at ten pounds or so maybe a little less, make sure your hitch is set a high as legal. Then go out and wax those winey losers on their p.o.s off breed green and red tractors!!!!! GO BIG ORANGE!
Allisman I know how you feel. I did find an even better solution this past year _ Its called a UC!! they really don't know what to think yet. I think they did not expect much, but they saw what hapenns when the weight was evened out. we will see how it works again this year. The UC has the weight that the wd and forty fives don't. Power is never an issue with A-C so no worries there. I have two U's this year to take and the UC . Should be fun. The UC is a few hundred heavier than the U, due to the final drives and there is also a plate of metal between the transmission and rear end on the uc that weighs about a hundred also. The dyno also usually shuts the other colors up I have found too!!!
Never had a UC to play with, figured those would have some pretty good lugging power. Whatever it takes to beat the red and green guys, especially the arrogant green guys! Yep really dislike the two cylinder tractors if they were anymore antiquated they would have reins and leave a trail behind them!!!!!!
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Most places have Pre 1957 or 1959 rules in place. Nothing after that year can pull.
Charlie
D19allisowner ![]() Orange Level Access ![]() ![]() Joined: 12 Dec 2011 Location: NE IA Points: 3044 |
You know why they paint john deers green don't you?
So they can hid in the grass when the AC's come along. |
