Wartime C
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: Wartime C
    Posted: 15 Mar 2012 at 8:21pm
Always interesting to see what the reserve is on some auctions. Heavy centers but short air stack. 2 plow set-up. Wonder if it has the cast iron parts?
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:34pm
Also has an Athens plow drawbar attached and made into a trailer hitch.
Has a distributer installed. Dont think that was original either, but was probably changed years ago.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:58pm
What makes it a wartime c? What's so special about them?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:04pm
This one falls into the serial #'s that would have come with factory steel wheels and some cast parts in place of regular steel due to wartime shortages. The heavy rear centers are for steel wheels.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:08pm
About 125 mi from me........Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 9:45pm
I can't believe a running C ( wartime or not ) can't even bring $500. That's pretty sad.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 8:32am
See, that is what has happened because nobody wants to spend anything..............
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 1:32pm
Would still like to know what reserve price was.
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 3:21pm
If one was trying to restore this to original it would require a lot of parts. Wrong manifold, air cleaner looks to have been modified, no batt box, and has a whine in the trans, who knows what else you'll find. I can't count the number of times I've been told a machine runs good and found iti to be the opposite. If I were local and needed parts I would not go over $500.
Edited by mdtractormechanic - 23 Mar 2012 at 3:28pm
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 7:24pm
ask larry obarr it is his tractor and he posts here from time to time
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 8:11pm
I'm guessing if you wanted the heavy centers and the double plow set-up it would run you close to $500 for that alone.
