tsx 464
jkoepke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkoepke Quote  Post ReplyReply Direct Link To This Post Topic: tsx 464
    Posted: 02 Apr 2012 at 12:23pm
working on a tsx 464 carb today pretty rough shape. Does any body know what size of tap to use on the nozzle jet to clean out the threads and also on the economizer jet. the nozzle jet i have screws in from bottom with screwdriver not from top  with nut type driver thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 2:30pm
Best thing to do there is pick yourself up a steel ball brush that goes in a drill. This is what I use on our customer's carbs when I rebuild them. It removes all the rust and debris that gets lodged around that tube in the canal, and it also cleans the threads out quite nicely. You don't want to run a tap down there when you're going to re-install that nozzle with the brass machine threads. Taps remove material, and that nozzle will be real loose going back in. The steel ball brush does an excellent job of shining up the threads and getting that nozzle canal cleaned out. I use the same ball brush to clean out the rust and debris in the inlet to the needle valve, and also the bowl drain..  HTH
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 2:58pm
