CUT OUT SWITCH WIRING FOR WD
C & J Plumbing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C & J Plumbing Quote  Post ReplyReply Direct Link To This Post Topic: CUT OUT SWITCH WIRING FOR WD
    Posted: 14 Jul 2011 at 9:43pm
I have a wd that is wired from amp meter to battery side of cut out switch. when you shut the tractor off you still have power to the opposite side of cut out if you disconnect battery terminal it cuts out. Wondering if  the  battery side of cut out should go to  the switch. Any help would be greatly appreciated.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 9:54pm
sounds like the cutout is stuck closed allowing current to past through the contacts.
Remove the cap and check the contacts. If they are stuck, gently pry them apart and check them for pitting.
Bob
