New to forum with 1958 D-14
tominMi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Topic: New to forum with 1958 D-14
    Posted: 23 Aug 2011 at 9:03am
I recently purchased a 1958 D-14. Tractor came with an AC loader, 2 bottom plow, side & rear cultivator, AC manuals and a couple other goodies the seller included. Tractor is very sound, good tin, original paint and no indication of any major engine or drive train repairs.
The tractor creeps when transmission is in gear and power director is in neutral position.  From other postings on the forum I've gathered that this is due to incorrect shimming of the power director clutch assembly.  I've also found the foot clutch travel is longer than the  distance specified in the manual.  A further inspection revealed that a piece  has been welded to the foot clutch adjustment rod ( approx. 3/4 -1 in.). There is no clutch slippage while under load. My question is this;  is the creeping  while the Power Director is in neutral  due only to shimming of the PD assembly or is it due to the extension welded to the foot clutch adjustment rod.
I am amazed at the collective knowledge and support of the forum members. Thanks in advance to all for assistance with my question.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 9:13am
Tom, welcome to the Forum. I recently acquired a D 15 and it does the same thing. Since this is my first D series I am still learning quite a bit. Correct shimming should correct the problem. The clutch extension should not affect it.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 9:28am
A small amount of creeping is normal, as the clutch is a wet clutch and the drag of the oil will cause it to creep, but you should be able to stop the tractor with the brakes. If you cant then you will be into it for a re-shim. The IT books actually gives a nice description on the procedure.
What part of MI are you from?
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:18am
Some creep when the oil is cold is normal from what I've been told. If it does it hot, I'd be concerned. On my D17, the detent plate that holds the lever in neutral was really worn. I built mine up and it stopped the creep when warm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:33am
Thanks for the replies.
Don I'm in the UP. I call the Sault home even though we live in the outlying township.
The tractor creeps less when warmed and especially so in the upper gears. When cold in the lower gears the creep is strong enough to over power light brake pedal pressure. Sounds as though an inspection & re-shimming /rebuild of the power director will be needed. Are shim kits available and where can they be obtained?
I have not changed the fluids, other than engine oil. Would too heavy an oil contribute to this problem?
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 4:06pm
Hi Tom,
I am from Presque Isle County, not too far from you in the LP, a couple of guys on this forum are from the UP as well, so you are not alone up there.
Heavy oil would contribute to it as well, they had non detergent 20W in the Power Director(Technical term for hi/lo range) from the factory, I use AW32 in mine because I use that in the hydraulics and power steering as well, keeps me from having to buy mulitple buckets of oil.
If it will over power the brakes, i mean you can stand on the brakes and make it stop but the motor lugs, it is most likely too tight and will need to be adjusted. Like I said the IT book gives a nice how too, and it sounds alot more complicated than it actually is, but you will need a set of calipers to do the measuring, or a set of split gauges and a 0-1 mic.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 6:48pm
Most D series 19's,17's and 14,15's will creep with power director in neutral.On our farm as a kid I remember all our D series tractors not creeping at all w. PD in neutral.Would coast to a stop when pulled into neutral.All our tractors were used daily.Later in life when I was looking for a D series almost all of the ones I looked at creeped in neutral,but most were hardly used. Someone told me a while back if you were to take that creeping tractor out and plow for the afternoon it would clear that problem up.I do not know if that is true or not.If the brake won't hold it then it may need re shimmed as manual describes.May want to take it out and put it through it's paces and see if that clears it up.Make sure proper oil is in power director chamber.Drain plug below foot clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 7:10pm
You don't remove or add shims to the power director. You move them from one side to the other.
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 7:53pm
Anyone have any pictures that show this?  My power director hangs up on my D14 and I'd like to fix it if its not a huge under taking.  How difficult is it to move the shims?  Do you have to split the tractor or is it something that can be adjusted through an inspection plate?
1958 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 6:05am
You can reshim be going through the cover by your right foot, no splitting required. And as Brian said no dont actually remove shims. That clutch is assembled with .205 worth of shims at all 3 locations, and this amount must always stay. You add or remove shims to adjust the clutch pack, and then you do the oppsite at the center plate. What i mean is if you remove .010 worth of shims at the clutch pack, you must add .010 worth to the center plates. If you change the .205 dimension you are in effect changing the length of the connecting links........
1968 D15D,1962 D19D
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 6:47am
I`ve noticed that some of the noches that is the neutral needs to be adjusted. If you can push the button down and move the lever and it stops the creeping, adjust the noch to that spot.
"Burgie"
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 6:47am
There is an easier fix for the creeping in neutral. More than probably the clutches are dirty. Drain the fluid out and refill with the red automatic transmision fluid. This is a very high detergent oil. It will clean the clutches where they are sticking. Try this first. It will be a lot cheaper fix if it is all that is wrong. You can then run the atf in the power director for a while if you want, it won't hurt anything.  Dave.
This page was generated in 0.077 seconds.
