200 knee removal
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 200 knee removal
    Posted: 02 Nov 2019 at 8:12pm
My brother is trying to repair his knee and spindle play. I did this a couple years ago on my 190 and as I remember the hard part was taking the steering arm off, however in his case getting the steering arm off was easy but he wants to remove the knees from the main front axle tube and he has them unbolted but he has not been able to get the me to slide out of the tube. Anyone have any tricks or suggestions. Thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:27pm
this is the part ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:56pm
Remove all three bolts on each side. Go drive it down a railroad track at high speed. That oughta shake things loose.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 9:49pm
Granted I only have 7 years of experience, but I have never had a problem with an axle knee rusting in the center section. You could take the largest hammer you can handle and rap on each side of the center section where the knee slides in. Once you take the bolts out, there should be enough wiggle to slide the knee out. Rapping with a hammer (or the vibration from running down a railroad track) should break up the crud thats holding the knee in.
www.awtractor.com
A&W TRACTOR 920-598-1287
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 5:44am
Tie the tractor down and use a port a power between steering arm and frame. Have saw them so tight that a port a power would barely move them.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 6:42pm
After I took the arm off, I ran the nut down flush with the threads. A few wacks with the sledge hammer and it popped loose. Had to replace the sleeves at the top and bottom of mine, its a 190XT so it may be different.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 8:43am
I had that problem on a D10 I had once;  I took the axle off and used a stump burner torch to heat the tubing with a porta-power between the spindle housings,
After the first one moved I secured it at first available adjustment hole and continued to the other side.
This is on a smaller scale but might help your situation.
Edited by JoeO(CMO) - 04 Nov 2019 at 8:47am
