What Am I Missing?
tamuron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tamuron Quote  Post ReplyReply Direct Link To This Post Topic: What Am I Missing?
    Posted: 25 Aug 2024 at 4:28pm
I have a Allis CA that I trying to fire up. Head Professionally re-worked, all new everything. Great Compression on all 4, Hot Fire and clean gas..6 volt system.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 6:28pm
Distributer or Magneto ?
Edited by Gary - 25 Aug 2024 at 8:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tamuron Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 1:25pm
Distributor
Post Options Post Options   Thanks (0) Thanks(0)   Quote tamuron Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 1:28pm
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:22pm
Timing?  Use a timing light to check
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:43pm
if you have gas and you have spark, then the timing is off... Rotate the motor to TDC on the front cylinder... Look at the distributo rotor and see that it is pointing at #1 lug....
Also the wires on the cap are 1-2-4-3  ... in a clockwise direction.
The FIRE mark on the crank is the ADVANCE position you will get when the motor is RUNNING... To START it should fire near Top Dead Center.
Edited by steve(ill) - 26 Aug 2024 at 9:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:54pm
Set timing to the fire mark at wide open throttle. Not at idle
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 10:11pm
if the head was off is the over head (valve lash)done on the right stroke
