Buying tires for my 38" hi-crop wheels
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Topic: Buying tires for my 38" hi-crop wheels
    Posted: 20 Apr 2012 at 8:29pm
I purchased my 1961 D-15 hi-crop tractor a long time ago, with 26" wheels and tires on it. Sits very low in rear. A few years ago, i found original adjustable 38" wheels for it. Fast forward to now and I am finally ready to purchase tires. I want to make sure I get the right tires. Measured my wheels tonight and they measure 11.2 across the rim width, measuring from inside the rim "lip". So does this mean I need to get the 11.2-38 tires?
Reason I ask is when I enter this tire on the Firestone Ag website, it lists the rim width as 10". Just trying to make sure I'm looking for and ordering the right tires for the wheels I have!
Thanks,
Tom
1961 D-15 Hi-Clearance
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:34pm
I believe a D15 should either have 11.2-38 or 12.4-38 tires on it.
I have 13.6-38 on my D15 high crop.
Can you post any pictures of your high crop?
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:42pm
The 13.6-38 tires that were also an option on this tractor, when entered in the Firestone Ag website, lists a rim width of 12". I need to get back out and check, but that may be my rim outer width from outer edge to outer edge. So...maybe those are the tires I really need?!
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:57pm
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:05pm
Thanks for the info. That chart is interesting. I guess my main trouble is understanding how to measure rim width in relation to how those charts denote rim width. Want to make sure I get it right. So here's a picture I took of the wheel.
Is this the way to measure it?! Outside to outside. This results in about a 12-1/4" measurement. Is this it?
Thanks,
Tom
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:16pm
Always  measure  inside  the  bead,        Not  out side. Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 7:52am
That looks like it would be an 11 inch rim.
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 6:45pm
Great, thanks for the info guys! So, *this* would be the right measurement then?!! Glad I asked! Does indeed look to be 11"...
Thanks again,
Tom
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 6:57pm
Yes, you have an 11" width rim, so 12.4-38 is the proper size tire for that rim.
Eric NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 7:15pm
My D15 II High Clearence with 13.6-38 rears and 6.50-16 fronts. Eric NY
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 7:23pm
Thanks, yes 12.4-38" it is. In looking at these tires, I've found some saying "tubeless". I figured there was a tube. I'm guessing that depends on the rim. I assume I'd need a tube?
Eric,
Nice to see that photo again! I actually have that photo saved on my computer from years and years ago from the previous AC forum at this site. My tractor is absolutely no match for yours and looks quite beat up and silly with the 26" wheels on her now. But I often check out that photo and dream about what mine can look like some day! Beautiful!
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 8:19pm
Shouldn't need a tube with tubeless tires. Just have to have the right valve stem.
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 1:41pm
So I can go either way then: tubeless tire, or tire with tube?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 3:12pm
If you buy the right tire. Tubeless tires usually say not to use a tube.
