Many, many Model B questions
Cestusrex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cestusrex Quote  Post ReplyReply Direct Link To This Post Topic: Many, many Model B questions
    Posted: 30 Apr 2012 at 4:19pm
I'm in the process of gathering information to help my Dad and uncle restore my Dad's 39 Model B.  Currently my uncle has the B partially disassembled and is trying to figure out the correct colors for the rims.  I've seen some 39s with silver rims on the rear and white rims on the front and I've seen others with orange all around.  We're not sure of the colors because my grandfather painted the B yellow and the rims an Oliver green after he put it back together in the earyl 50's.  And when I say put back together I mean put back together.  He got the B as payment for some work he had done in his machine shop, the only problem was a tree had fallen on it and broke it in half.  From what I can tell the tree landed right where the hood meets the gas tank (which it put a big dent in), broke the steering tube (which was replaced by a piece of drain pipe), and then snapped the bell housing/frame in half (which grandpa welded back together with some bar stock welded top and bottom and both sides for reinforcement).  It then ran for the next 50 years patched back together.  Its been sitting for almost 10 years and my uncle, a retired farmer (though I don't know how you become a retired farmer), has decided to take it on as his next restoration project.  The engine is free but the magneto is frozen up.  Also trying to figure out which muffler is correct because it hasn't had one in some time.  Thanks for any help.
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 5:35pm
Paint will be persian orange #1 code is(ppg 60080). Back rims will be silver. Muffler depends on what motor you have. The flattened pipe style exhaust was used on gas B tractors before engine serial# BE-43896   AN oval underhood muffler  was used on tractors between  BE-43896 and 114400  After those numbers it will take  a narrow upright muffler that has a flap that mounts to the manifold.
Edited by irlbeck A-C'S - 30 Apr 2012 at 5:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 6:36pm
The back rims weren't painted originally. They were galvanized. The rest of the tractor including the front rims would have been painted PO1 from the factory.
 Probably didn't have a muffler originally. The "flattened" pipe does seem to cut the noise level down some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cestusrex Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:42am
Thanks for the help.  My next question is about manuals.  I've seen that there are several available for the B but are they just general overviews or are there year specific ones?  We really need a parts manual for the 39 model year (serial number 22419 to be specific) and an owners manual would be nice.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:54am
A Dealer Parts Manual available online will answer most of your questions, unless you are going to be obsessed with the details of originality.
If that is the case, you will need to search out early versions of those publications and purchase them when you find them. There are a few on here who have older copies that come in handy for specific references, and it is good to get to know them, as the books themselves are quite scarce. It is a great way to waste time on winter evenings, obsessing over minute details and emailing back and forth with your friends about it, as well as hunting for new clues or documentation that confirms your hunches, etc. I confess to being ever so slightly obsessed with the B tractor and implements, and have been known to have rather lengthy phone calls with friends about some pretty arcane stuff.
The most important thing is to have fun, and once you are doing that, it is all worth it!
Good luck.
Edited by GlenninPA - 01 May 2012 at 9:55am
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 12:53pm
That sounds like a most interesting B. Would love to see pictures.
Broke in half. Welded back together. Pipe for a steering rod
Great resourcefulness.
Just goes to show what my favorite can take.
Look further to further reports
Good Luck!
Bill Long
ps: For mag work don't forget Steve NJ. He has an ad on this forum. B & B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cestusrex Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2012 at 9:37am
I was going to post some pictures yesterday but the file sizes are too big so I'll have to try again later. The pictures I took were from the front, rear, and side and showed where it was welded back together. One also shows that it doesn't have a pto and that where the staff should be sticking out there is just a plate.
