Trying to ID an early serial# "G"
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Topic: Trying to ID an early serial# "G"
    Posted: 04 Oct 2016 at 3:48pm
Hey guys, back in June I purchased (2) model "G" tractors. One of which has the manual lift and looks to be an early serial number. I know VERY LITTLE about these tractors and have been told to look at the number near the shifter as the serial number. Well.....that number is very hard to get your eyes on and from what I can tell, it reads "G(2,3,8)64". I can't tell whether the first number is a 2, 3, or an 8.
Is there any other place the serial number might be stamped? What about trying to date it another way such as casting codes? I own a bunch of Farmalls and you can do it to them.
Please help!
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 3:50pm
Here are some pictures......
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 3:52pm
more pictures.....
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 3:54pm
and 1 more picture................
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 4:40pm
That first impression is the letter G, the model letter.
Gerald J.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 7:34pm
I see G26461.  My G is S/N G2004. It's a 1948. Yours is later. If I had Swinford's book with me, I'd look it up and tell you what year yours was.
By the way...you mention casting numbers...You can do that with Ford tractors and B Allis engines too, but I'm not sure about the G.
Edited by CrestonM - 04 Oct 2016 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 7:55pm
Per Norm's book, end # was 10960, for 1948...
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 10:14pm
I see G26451.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 4:31am
I must be blind, and I have my glasses on. All I see is G264, no 51 or 61 after those numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 6:29am
Take a soft wire wheel and lightly remove the paint THEN use a strong pinpoint light AT AN ANGLE look at the casting AT AN ANGLE. You'll have to 'look from at sides' and eventually you'll find the right combination to light and angle to see the numbers.
It gets harder the older you get though.......
Jay
Edited by jaybmiller - 05 Oct 2016 at 6:30am
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 7:27am
X-2
Dusty
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 8:06am
Thanks guys, willl have to get in there and see what I can find. It is a tight spot to get to but I will try my best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 8:21am
I see the G264 clearly if there is a digit after that it is very faint, more likely half a century of rust. The vertical mark after that looks like a 1 but its a different size than the other visible digits. More likely a scratch from an implement part.
There will be an independent serial number on the engine but since it was not made by AC and not unique to the G, correlating the two serial numbers will be difficult, needing the factory build log if it exists. A good Continental parts dealer like http://montesequipment.com/
 might be able to show a year for the engine.
Gerald J.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 9:52am
Originally posted by truckerfarmer truckerfarmer wrote:
I see G26451.
Thats what I see as well.
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 10:11am
According tp http://www.allischalmers.com/serials.html G26451 would be a 1952 model with the serial numbers for that year ending with G26496.
Gerald J.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 6:56am
Must been a tall guy that owned it ,see where they put a spacer to make it longer.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 7:02am
Looks like G26451 to me.
 That torque tube extension could be an accident waiting to happen. The ears on the torque tub, not having a place to clamp to that is flat and solid, could very easily snap off.
It has happened on some G's before.
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 8:05am
I see what you mean. Thanks for the advice. I was wondering why that spacer was there. Figured it was required when using that mounted plow. Did A-C make a factory spacer that would work better? I should probably take that off next chance I get. This one isn't running right now and I need to dig into it to get it going.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 9:14am
No, Allis didn't make spacers, sore knees did!
+1 on getting it off before the ears pop!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 9:39am
Is it ok for it to have a properly made spacer? Apparently it is/was a common practice to do this?
L. Hill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L. Hill Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 12:40pm
Chase
What part of Al are you in?  We are having a tractor show at Noccalula Falls in Gadsden, Al
October 14-15. It is called "G" Round Up. Would like for you to come. We have plenty of information on G's. You can call me at 2564906134. Thanks! Lenn Hill
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 1:13pm
Originally posted by L. Hill L. Hill wrote:
Chase
Thanks Mr. Hill I came to it a few years ago and brought a Farmall Cub. Good show. I hope I can find time to make it this year. Probabaly won't get to bring a "G" though due to lack of time to prepare.
rtr View Drop Down
I am located in McCalla, AL just outside of Bessemer.
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:47am
Took the seat off yesterday and hit it with a wire wheel on a grinder. "G26451" is what I read. It was still hard to read but that is what I got and since several of you agreed I am going with it. I was really hoping it was an early serial number, but oh well.
Ended up charging the "new" 6 volt battery on it to see if that was the issue causing the problem of no juice to start. I then unhooked the (+) battery cable to check the ground. When I did, the ground cable sparked. That told me there was something "on" or grounded out. On/off toggle switch in both directions gave me the spark, then I realized that checking the ground continuity at the tractor frame, the (-) battery cable to the starter faulted as a ground. It was very frayed and (probably original) I made sure nothing was touching it. Still my meter beeped. I decided that starter must have been bad and grounded out, so I removed it to be repaired.
This page was generated in 0.211 seconds.
