PTO Noise
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Topic: PTO Noise
    Posted: 04 Apr 2011 at 8:44am
I'm needing some advice Guys....
My '52 WD has developed a knock in the PTO when it is working. When idle..no attachements..it is still noisy but sounds more like dull click-click.
 What should I be looking for and how to get to the problem?
Thanks
Life is short...Make haste to be kind
Harold (MID MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harold (MID MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:52am
Sounds like a missing or severly chipped tooth in a gear.  Pull the PTO gearbox off the bottom of the torque tube and check the gears in the PTO box, and the gear in the torque tube that drives the PTO box.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 11:55am
I agree with Harold, almost for sure a broken tooth and likely is on the gear directly above the pto drop box. We stock new and used ones & can give you advice on how to replace it without spliiting the tractor.   Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 7:52pm
Thank You Gentlemen..I'll have a go at it . At least I know where to start & what to look for now.
Thanks
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:01pm
  we have the gears also an can be repaired without spiltting it also
   1-800-254-3116
