I sunk my kubota
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Topic: I sunk my kubota
    Posted: 11 Oct 2010 at 7:06pm
160 CA 920diesel 5020 HD-3
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:09pm
 And you did a very good job of it.
PBSoMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:15pm
 Man, I hate it when that happens! Did you get it out with out tearing up anything? That ground looks a little wet?
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:17pm
Holy mudcakes, Kip! Good thing that tractor found something solid down there or it's have sunk oughta sight. Have you gotten her out yet?
WC, CA, D14, WD45
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:23pm
you should have given up a lot sooner!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:23pm
I hit clay about 3ft down.  It sunk fast we had the 160 on and wont move it and a 185  the ground is too soft to pull me out.  I have a buddy with a jd 450 dozer coming over to tomorrow try.  The spin marks in the back ground are from the 160 with ring chains on. I was only sinking about a inch or 4 up til this point I found a spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:52pm
Friend of ours buried a 966 Int'l a few years back, same thing was running in 'soft' ground then the bottom fell out at a spring or sinkhole; they had the tractor so deep you walked off from the cab floor, took a D-8 to get it out!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:56pm
i have seen 80 ton dozers stuck to the cab.. i can tell you the mud suction is hard to overcome. if you have a backhoe, you can dig out behind or in front of it and build somewhat of a ramp upward. thats the only way to get some of them out. if no hoe, you can use  a  bucket or small dozer to make a couple passes and take out 2 feet to get a start. everything helps when your in that deep.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:59pm
OOPS -- she's in there good. Sort of slowed down your day a bit. Hate when that happens.
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:01pm
On a Monday yet, what a way to start your week.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:02pm
Kip, it looks like the spring needs to be cleaned out, so while you're in there now would be the best time
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:03pm
Be careful not to break it when you pull it out with the dozer.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:29pm
WOW! That is 100% stuck. You need to send us some pictures of the get'n unstuck part too. Let us know how you make out. Be safe and good luck Kip.
1954 WD45 NF "Iron Tater"
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:48pm
Yep, that there be stuck. I think you should try digging around it with the dozer(make sure you don't get it stuck too) before you start yanking on it, or you'll break somethin good for sure!
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 9:53pm
Yup, your in pretty good, not real bad yet like where the top of the hood is going under.
 Whats out front? More swamp or harder ground. If its terra firm heading forward the take a good beam and lay under the loader and raise the front end up as high as possible, (by lowering the loader). Next dig the mud from the wheel tracks and some from under the belly. Then lay couple more timbers under the front wheels back to in front of the rear tires, being sure to leave them in a ramp fashion.
 then hook on and Give a good pull. have used cable on tires to walk out on but then let a couple #s air out so cables will tighten in center of tire face.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 10:02pm
Looks like a job for the HD3!
ALLIS EXPRESS!
This year:
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 10:22pm
Dang... hold on and let me re-phrase that... DAAAANG! Good luck. If I was closer, I'd come help out just to see it all happen. By the way, if you get a chance, send us part of that rain down here in KY!
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 10:29pm
Dang that hole is wetter than our ponds. Only thing you can sink in that deep around here is dust holes where we had a D7 clearing a fence row last week and he had to dig holes as deep as his hood to get the big trees to fall over.
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 10:29pm
Wow!!!!   Thanks for posting pic Kip.Good luck and be safe.There are probably not a lot of guys who would ever post a pic about a mishap on here.(Me for one)LOL,Just kidding,glad to see i am not the only one who had a bad monday.Went to change a lower element on a water heater today.Turned valve off on top of heater.Checked faucet in bathroom to make sure hot was off.Screwed element out and water started spraying out full pressure.Could not get element to go back in.Turns out valve was on hot side and the cold feed was still on.Had to hold element in place with water shooting out until utility could shut main off.Took them 15 min to show up.Customer(little old lady)could not get in crawl space and she couldn't hold it while I found shutoff.No one around,nieghbors unable to help.She turned everything on and pressure lowered but still sprayed out pretty good.Needless to say lots of water damage.Cleaning service was setting up as I left.Boss was not happy.Valve was on a horizontal pipe and I did not notice it was on pipe exiting heater.Who ever installed put the valve on wrong side.AAARRGGGHHHH !!!!!!!!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 12:58am
Pat, looks like there is one more thing a plumber needs to know, "If there is a chance it was done wrong, it probably was!"
Allis Express participant
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 2:03am
Kip if you need my backhoe come and get it. Keys are in it. I'll tell you how to get it started.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 7:19am
Nice job!  You do better than I do.  The worst I ever did, I pulled the D14 out with my buddies M Farmall.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 7:40am
You done good!  I say if ya going to screw up, make it memorable!
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 8:12am
One of the few things I learned in the Army, other than don't volunteer, was getting a tank unstuck. Used this to get a stuck Cat
D-6 free from a silt hole on the railroad in Rouses Point, NY. Fastened a heavy hardwood plank to the rear of the tracks with short chains, put the dozer in reverse and it pulled the plank under with the dozer rising up out of the muck. Be careful. Bob@allisdowneast
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 8:16am
 I should have more photos tonight  Iam getting  help from the folks up the road their jd dozer is closer then my HD3.  The part of this hole thing is I sold my backhoe last year to buy this kubota.   But Iam going to make a huge mess of the feils before the day is done.
JohnDNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnDNY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 5:19pm
If I was you I would stay off wet ground. Not doing much good anyway.
