please help wd?????
beaker41 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaker41 Quote  Post ReplyReply Direct Link To This Post Topic: please help wd?????
    Posted: 10 Sep 2010 at 7:31pm
well i am new here  and i need some help i bought what i think is a wd but  i am not sure because i have been looking at a lot of pics of them and there is a lot of diffrences  between them and i also have an operators guide for a wd  and on talks about stuff that i dont have on my tractor such as feet brakes i do not have they are hand brakes the throttle is diffrent form what the book says but there is a stamping on the rear of the gear housing (pumpkin) that says "tractor wd R-996 i was told that it was a 1946 wd but they were not made that early i am pulling my hair out trying to figure this out
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 7:45pm
Sounds like you got a WC. Styled WC's were made from 38 to 48 and had hand brakes. the sheet metal is very similar to the WD. Post a picture and maybe show us where you found the wd R-996.WC's also had a shifter that came straight up and then a bend with the longest part of the shifter bent toward the rear of the tractor. WD shifters were short straight up. The WD also had a lever opposite the throttle quadrant that ran the hydraulic valve. WC's had no hydraulics.
Edited by CTuckerNWIL - 10 Sep 2010 at 7:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaker41 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 7:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaker41 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 7:49pm
the wd r-966 is under the seat on the axel housing
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 7:54pm
Beaker, are you sure that ser# doesn't say WC xxx? If you have hand brakes you most likely have a WC. They are very good tractors, but don't have a lot of the advancements that the WD had. Does the rear diff housing look kinda like what came from a heavy truck? Smooth and curvy? WD was more squared looking. WC was curvy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 8:02pm
Tractor number location for WC. http://people.clemson.edu/~wsmth/SNLocat/ACSN3.htm
Tractor number location for WD. http://people.clemson.edu/~wsmth/SNLocat/ACSN4.htm
You can see some of the differences between tractors by looking at these 2 links.
