posting pics
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Topic: posting pics
    Posted: 06 Sep 2010 at 7:57pm
Can somebody on here please help me figure out how to post pictures on here. Thanks in advance.
                                                     Mike
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 8:23pm
When you start post look in the toolbar above the message board for a tree symbol. Click on the tree. you will be able to browse your computer for the pic you want to post. You will most likely need to resize the pic lets just say 600 x 400 for example. If those numbers are off your pic will be distorted. Type in any text you want then post your pic. Here is a link from another topic.
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=17701&title=how-to-add-pictures
Edited by irlbeck A-C'S - 06 Sep 2010 at 8:37pm
Bob J (Wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J (Wi) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 8:57pm
My picture file is larger than allowed. How do
I correct the size to fit.
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 9:00pm
I had the same problem and I still haven't figured it out.  Curse this technology.  LOL
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 9:02pm
You can post it on photo bucket and resize, use some of the other photo programs . I have used the snipping tool in Win vista and Win 7 to make another copy . you can also change the numbers when posting here to proportion it smaller .
 Also you can use the search feature on this site to look up other ideas or ways to solve the problem .
Edited by Coke-in-MN - 06 Sep 2010 at 9:04pm
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 9:09pm
if you have windows look and see if you can open the picture with MIcrosoft Picture Editor.  They have a Edit Picture Menu at top, in the menu it has a section that says Resize,  if you click Resize it has choices, I usually use 'document medium' or 'document large', about 600x800 is plenty big, that will reduce the size so it works and fits the screen better too.  After you resize you will have to save the picture, to the same name if you don't want the original picture anymore or to a new name like pic_small.
Seems like a lot of work and it is easy to get lost when you actually attach it to you post.  I still have trouble with getting the text and picture how I want it, multiple pictures still gets me lost.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 9:11pm
When I post pics I chose the one I want and then click on edit, then I can click on image and use skew/stretch. If I change the % on height and width to 33% it comes out just the right size. I've tried Photobucket and never did get any pics posted, not sure what I did wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 10:03pm
Thanks alot guys finally figured it out, now I just have to play with the sizes.
                             Thanks again, Mike.
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 10:09pm
here is my try
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 8:36am
i'm going to try this lonny. my pictures are always too big.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 11:37am
After you upload the picture, before posting click the preview and see what size the picture is. If it is bigger than 800x600 it will be too big to see on the normal page. You can change these numbers but need to keep the ratio the same between height and width.
