ugly but oil cooler is functional
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: ugly but oil cooler is functional
    Posted: 11 Jul 2010 at 7:12pm
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 7:31pm
I like your Idea. Could it be mounted infront on the radiator behind the grill? I was having cooling issues but took out most of the water/orange antifreeze mix. and put in water wetter and just water. Now it don't heat up any more. I was thinking of using a electric fan infront of the radiator to cool down inbetween pulls. Thaught I had enough room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 8:12pm
  I couldnt get the lines bent tight enough without crimping them to go behind the radiator shell/nose . I have no water in the block using oil to cool block.
bikley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikley Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 8:18pm
If it works who cares what it looks like
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 8:38pm
I like to keep installations clean and neat. It just looks like a after thought to me even though it was in the plan from the start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:08pm
Can you have braided steel lines made? I guess it depends on if there are right angle or other ends available to keep from kinking.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:11pm
how much longer til she pulls, i wanna hear how it does, a video would be awesome
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:15pm
I've always been a function over form kinda guy. pretty doesn't make it go faster (or further)
I am still confident of this;
Wait for the Lord;
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:41pm
If you use a simple tubing Bender, you can make nice clean, bends, and easily put the cooler behind the grille and not risk getting the tubing snagged, or risk it flapping around loose.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:49pm
It would be alot of repluming but I bet the filter housing could fit inside the frame where the Hydrolic pump was. It might be nice to try it out before you where to do anything else to the system. You may need to modify it. Its a great idea.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 10:00pm
I am sure as you prove it out you will have it perfect, my first thought was DrAllis was helping by hanging a IV bottle.!!!!
I wish I had "fun" problems that showed results
I want to hear it also....!!!!
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 2:37pm
Use hydraulic lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 3:29pm
you will have to cut the bottom of the grill shell to get 3/8 od line up between it plus the inlet/outlets have to be at the top or cooler can trap air and cause cavitation. I could use pipe and 90 degree fittings to get it turned down before going to flare fittings.
Edited by mlpankey - 12 Jul 2010 at 3:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 4:04pm
Two bulkhead fittings (flared or compression)  mounted in 3/8" holes drilled in the bottom side of the grille shell would work well. The cooler could be plumbed as one piece inside the grille, and be connected on the outside with two fittings when mounted. Plenty of room to bend loops in the tubing at the top of the cooler to minimize joints as well. Just a thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 5:08pm
I guess I'd be concerned about how many seconds it takes to establish oil pressure each time the engine is started with a mile of plumbing....I have one of my engines "hard -blocked" and have always felt if I had to make more than three runs at an event I'd drop the oil in a clean jug and refill with cold oil (keep the two jugs and alternate which oil is in the engine). I run stock RPM's and not "open" RPM's so I've never needed to do that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 6:26am
 Dr. the oil filter being turned down so it will not drain back 2 quarts in the oil cooler . Also the oil pressure is brought up before its ran lines charged with oil so they are no seconds waiting on oil pressure. the old style d17 pump will supply several psi so thats why we have the hp1 performance filter on her.
