Items going to OPOP |
Post Reply |
Michael Crowe
Orange Level Joined: 11 Sep 2009 Location: Kansas City Points: 1722 |
Posted: 09 Jul 2010 at 1:15pm |
Guys I will have room for smaller stuff; let me know if interested and I will bring it. Items listed are for a WD/WD45 unless otherwise stated. Call me at 816 898 7277 or email or pm me with questions/prices.
For WD/WD45/WD45D: Set of 3 stack weights, tricycle adapter for wfe, flip over seat bracket, distributor conversion, pto shafts, pto drop housing, hydraulic cylinders, crank, hydraulic pump, motor parts, PS motor, PS pump with bracket, nice 3 bolt wide front, transport valves, w line/filler; 45D filter plate, starter rod, throttle rod with fuel shut off lever/spring, fuel injector lines, return line; For D series: transport valve, belt pulley lever with good knob, D15 3 point sway block with chains, dash plug for hour meter, D 17 fuel filter cluster; For C: hood (dented but usable) w strap, clutch/pressure plate, air breather (no cap or bottom), temp housing with gauge, head/manifold, gas tank support: For WC: brake extensions, NOS WC crank pulley; For CA, traction booster gauge with bracket, wheel stops; Misc: NOS spoked wheel for rubber tire for plow, NOS MS Carburetor TSX 875,NOS steering box for D12( I think), NOS Fram Oil Filters, NOS Coop Oil Filters, NOS Unico Oil Filter; AC disc hitch, B drawbar braces; Case ensign lpg carburetor |
Michael Crowe
The flip over seat bracket and 2 NOS Fram Filters are sold. Michael
Michael Crowe
The D series transport valve and belt pulley engagement lever are sold. Thanks.
Post Reply | |
