Whoever said low compression...
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: Whoever said low compression...
    Posted: 30 Oct 2011 at 6:25am
you were right. My wc has between 25 and 50 pounds of compression. I'm amazed it runs at all. lol... Guess I'll add that to the list of things to do in the spring.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 6:53am
 I have a 460 in a pickup that had 2 cyls at about 80 lbs and 6 cyls at 40 to 65 lbs and we used it all winter to fetch firewood. It was necessary to park near the plug so the charger could assist in getting it to roll over fast enough to start when cold. It was amazing what a set of rings did for it!
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 7:42am
Glockhead SWMI, I ran a MF that had numbers like that and it ran pretty good.
The only problem was alot of gasoline was getting into the motor oil.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 9:50am
Should be easy to crank! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 10:11am
It sure is! Runs good but starts hard. Not sure what I'll do yet. Might tear it down and see how the cylinders look. A cheap rebuild would be nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 10:56am
Hone it, ring it and run it another 25 years.
