No go
7040 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Topic: No go
    Posted: 16 May 2017 at 5:09pm
I have a 7040 ps tractor i have pto and three point Hitch but the steering is stiff at low idle as you rev up the motor becomes easier and the light stays on at 1800 but the most trouble is there is no go in any gear in high or low range please help
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:53pm
you have a sticking flow divider valve as to the steering issue, the no go is possibly a gerotor pump issue - have you checked the dipstick in the cab floor for oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 11:23pm
Yes the oil is full under the seat I hope it's not in side the transmission
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 7:57am
Can you tell me we're is that located on the tractor gerotor pump is at thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 11:23am
Look like the oil is over full in the transmission by a half inch would that cause it thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:46pm
There are three pumps bolted to gather under right fuel tank. The gerotor will be the last one to come out. It will bolted to back of gear pump. I would guess both pumps need looked at.
Have you changed hydraulic filters lately?     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 10:20pm
No I have not, should do all filters first that could be my problem ? Because we parked it and went out the next day started it up went to start Field work Move a little then nothing. Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:14am
No, if left filter was changed and screen was not put back in, it would affect the steering.   Just sounds like it is in the pumps.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:24am
With the Range lever in neutral (or park) and clutch pedal up,  throttle the engine up to 1800 RPM and slowly shift the Power Shift lever from 1 to 2 to 3 to 4 to 5 to 6th gears. If the transmission pump is the issue, you should probably notice  no change in the engines noise level as you progressively upshift the transmission. If the engine governor opens up a bit with each upshift, that is normal and  your problem may be in the rear end or range transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:38am
Your power steering issue isn't related to the tractor not moving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:18am
Thanks Dr Allis I will go out and give it a try I will let you guys know what happens you guys are GREAT THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:03am
Ok guys went outside and did what Dr Allis said and when I shifted though the gear no different in the motor whatsoever and did it few times down the gears and up the gear no different what's next THANKS GUYS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:53am
Make sure the inching pedal linkage behind the fuel tank is connected and pushing the  valve spool in and out. Takes two people to watch things. If your 1800 RPM light actually works and it is on all the time, that sounds like a transmission pump problem, but only a 300 psi gauge can verify that to be absolutely sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 10:02am
Thanks Dr Allis I have to wait for my son gets home from work to check things out I will get back to you later tonight THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 4:29pm
Mack I think you're right did all test what Dr Allis said still have nothing when the pump goes out does it do anything to the transmission? And is the pump right in front of the fuel tank and can you get it by drop the skid plate
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:28pm
Oily job ahead. Drain transmission, remove plate behind pumps. Remove screen from where you removed plate. Remove cover from left hand filter. Remove lines from front pump and plug line from serge chamber. Remove two 1/2 " bolts holding front pump and remove. Remove lines from gear pump, remove three 3/8" bolts holding gear pump in. Pry pumps forward. They may not come easy, there is two Owings that has to slide through housing.
Good luck and enjoy the oil dripping on you lol.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:47pm
Thanks Mack I thought that were it was thank for all your help and Dr you guys are the best I will keep in touch is it ok to pm you with questions ? Thanks again
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 10:35pm
This is the pump setup on an 8000 series, yours will be very similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 10:51pm
Thanks! that helped a lot does that cost much money to fix funding is tight
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 4:13am
Yes it be expensive and yes you can pm me.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 12:10pm
Thanks Mack start this weekend on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 9:51pm
Hey guys, Iam looking for a gerotor pump for a 7000 series mine is a 7040 that runs the transmission the other pump is fine,is there anybody that might have one for sale and how much, you can pm let me know, thanks steve
sason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 7:09am
I have both pumps off a late 7040.
Will take 400 for main pump and 200 for gear pump
180 with a turbo and 460 loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 7:27am
how did the pump fair for you? get it running yet? have any other issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 12:14pm
The pump work great, we are up and running, shifts really smooth. Thanks for all the help on this site there's a lot of knowledge. Mack you take care of yourself. Thanks steve
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 7:36pm
Steve, good to hear your 7040 is going again. We are lucky to have people w/ knowledge and experience on here. Good thing you didn't call me for help. Like I told you awhile ago. The only thing I know about them, is I like them. lol  Tim
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 9:51pm
Glad to hear it is fixed.     MACK
