Hyd leak 8010 |
Post Reply |
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1353 |
Posted: 12 Jun 2018 at 7:35am |
8010 ps started leaking behind the right fuel tank close to the rear. There are hoses there but it's deeper than I can see. I will start on it tonight by removing the tank. Has anyone had a leak in this area? Any experienced advice is appreciated. Scott
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
I had a hose wear through behind the right hand tank. We replaced every hose that we couldn’t get to without removing the tank at that time.
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2876 |
Been their done that on a 8030. Pumped the fuel tanks out and pulled the tank. Time consuming but manageable.
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2257 |
Remove the tank. Lots of hoses behind there. Most are likely original. Replace as needed. The Power shift hoses are usual suspects.
allisrutledge
Thanks for the replies, I got the fuel pumped out this afternoon ,then I got a call and a tree fell on a line fence. So I'll get back on it tomorrow afternoon. Scott
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8304 |
How many lines back there
allisrutledge
I found the pilot line leaking . small hose from the pump to the external valve. To answer Mike ,there is between 11 and14 if you count the upper hoses. I don't know if it is different on a pd trans. I cleaned everything and left that tank off for the meantime to see if I can make it on the fuel the main tank will hold. Will probably be putting it back soon. Not a bad job just as said ,time consuming. They never breakdown if you don't use them hum ,must be a conspiracy.the mess behind the tank you cannot clean unless you remove the tank
Post Reply | |
