stuck engine in a 47 B |
Post Reply |
GT in Indiana
Orange Level Joined: 14 Sep 2009 Location: Indiana Points: 213 |
Posted: 06 Oct 2017 at 1:16pm |
Has anyone ever tried putting boiling water in the cylinders to break loose a stuck engine?
Curious, GT
1955 WD45 we like to call Ruby
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 691 |
I have not and honestly, I would not.
I just freed up the engine in my '51 B. I mean just, 2 days ago. This tractor was my Dad's and was parked in the basement of his barn. Inside, but humid. I tried atf and kerosene through the spark plug holes for a week plus, rocking the tractor in 3rd gear twice a day. Then I went with atf and acetone for another week, doing the same thing. Then I got smarter and pulled the head off. The exhaust valve on the #2 cylinder was wide open and #2 had surface rust on the bore. I tried atf and acetone for another several days and got, maybe, 1/4" of movement pushing the tractor in 3rd gear. Then i got slightly smarter and cleaned out the #2 cylinder, removing all of the oily schmoo and filled it with Evapo Rust. In 24 hours, all of the exposed rust was gone. It's not acid and does not eat into good metal at all. I was able to move the piston down another 1/2", which exposed more rust. I put the Evapo Rust back in for 24 hours. No more rust. After that, I removed the Evapo Rust and put the atf and acetone back in, let it sit overnight, then put a pipe wrench with a cheater on the PTO and firmly (but slowly) pulled clockwise. With just a little pressure, it broke free. It now rotates freely. Personally, i wouldn't use boiling water because if it doesn't free up, you have introduced a huge source of rust. I also would never again try this without starting by removing the head. I've learned my lesson. For me, it was worth it to take it slow.
Edited by HoughMade - 06 Oct 2017 at 2:09pm |
1951 B
Genuine1979
Bronze Level Joined: 01 Sep 2017 Location: Bedford, IN Points: 13 |
Good info! I am currently dealing with a stuck engine and will start here. Thanks!
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
How a person goes about getting a stuck engine running again depends on several factors. Do you just want it to run regardless of performance. Time is another factor. Do you want to take months to get it running or are you wanting running right away? Money available to get it running is one of the main factors. Not having much money to put into the project does limit your choices.
The quickest way to get in running at top performance would remove the engine, strip it down to the bare block, after proper prep, install a new engine kit and have the head rebuilt. I personally would never try to unstick an engine without removing the valve cover along with the rocker arm assembly and make sure none of the valves are stuck. Stuck valves can freeze an engine from turning just like stuck rings. Then if none were stuck I would remove the head to see what I was working with. This would be when I knew it had never set out in the rain where water could get into the cylinders. If it has set outside in weather for an extended period of time I would totally disassemble and work my way back to every part being in spec. Not necessarily new parts. Having a source of used parts to measure to make sure they are within spec can save a great deal of money. Seven years back I took a badly rusted stuck engine and rebuilt it with all used parts except for rings and bearings to prove that you do not need spend the farm to have a top performing tractor. I put this in an Allis Chalmers C which has been my main mowing tractor since. Look At Pictures Below. https://public.fotki.com/DickL/allis_chalmers_engi/allis-chalmers-c-st/ |
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Making the rods push a stuck piston up can bend the rod, usually in a direction to put more bind on the piston pin, and rod bearing. And that can lead to a broken rod when its running and a new inspection hole in the side of the block where the broken end of the rod comes out. Its not a good idea to crank a stuck engine.
Gerald J. |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7304 |
Many engines get stuck from water getting inside them. I really doubt that boiling water would free it up. Best thing to do is to take the head off and soak with ATF and acetone. Let it work for as long as it needs. DO NOT RUSH trying to free it up, you'll just end up having to spend more money. Once you can move it, put new pistons, rings and sleeves in it and you will be good to go. But also take time to clean and inspect everything else.
GT in Indiana
Glad i didnt try to break it free without taking it apart...
Thanx guys
GT in Indiana
GT in Indiana
Post Reply | |
