53 WD no spark
Brian L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian L Quote  Post ReplyReply Direct Link To This Post Topic: 53 WD no spark
    Posted: 22 Feb 2020 at 2:21pm
I sold My 53 Wd parts Tractor it was stuck in 1st Gear got that fixed.Used to be a Fork Lift.Tryed to start but not spark.Put in new points and Condensor still nothing changed the condensor twice.I have power to the points but no spark.Could i have a bad ground to the base plate on the Distributor.Any thoughts Please
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 9:38pm
Just some thoughts from an old man.  if Mag Think of a roto, cap, and coil.
Good Luck!
Bill Long
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 10:02pm
Mag or distributor?           MACK
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 9:47am
Kinda sounds like one of my C's right now LOL!! --- I even took the guts from a running tractor and put in it. ---Juice across the points, BUT none to the plugs. Still nothing with the running tractor parts installed in this one either. --- Kinda a head scratcher!
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 10:48am
When you roll it over with the cap and rotor off do you see a spark when the points open? Did you try a different rotor? Had one where the tab was bad and not contacting the cap. Is the button in the center of the cap in good condition? What about the coil. Did you take the wire from the center off the cap and hold it a 1/4 inch from a ground and roll it over to see if the coil is sending the spark out to the cap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 12:18pm
The whole cap/wires/rotor/condenser/points/plugs/coil/etc were used, still no fire at plugs.Would like to use this one this spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 2:53pm
To be sure the points are working,pull coil wire out of distributor,remove cap and dust cover,turn engine so points are closed but can be broke open by twisting rotor moving the advance. Ignition on,hold coil wire 1/4 in from block and twist rotor. Points should have slight spark and blue spark jumping to block from coil wire. Good spark will jump 1/2in. This assumes you have points set so they close and open correct amount.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 9:48pm
Terminal going through distributor could be grounded.       MACK
