Generator ? |
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Topic: Generator ?Posted: 03 Mar 2020 at 5:54pm |
Terminal on left is marked A, terminal on right is marked F, armature and fields, what is the 3rd terminal?
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1076 |
Posted: 03 Mar 2020 at 6:33pm |
Ground
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24781 |
Posted: 03 Mar 2020 at 6:37pm |
Ground ! yeah, that's what it is. Without it , power has to go, hopefully, from what ever nuts and bolt attach the genny to a bracket, then bolts to the block, then to a bolt for the ground wire, then to the battery. Those are a LOT of 'points' where power may not get through. 1/2 amp here, 1/4 amp there....hmm...never get full charge syndrome. Smart guys run a separate ground from genny/alt to battery post that is ground. 'Old skool' for reliability. |
TMiller/NC
Posted: 03 Mar 2020 at 7:07pm |
Thanks guys
