GENERATOR ENGINE PARTS
Message Reverse Sort Order
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: GENERATOR ENGINE PARTS
    Posted: 27 Aug 2022 at 9:03pm
I had a 50kw set powered with an A-C engine and had no problems with Baldwin branded filters. All numbers needed were current with them five years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 2:55pm
might be worth calling these guys and discussing... They probably got a better idea of the application..im not saying this is the correct kit, but these guys seem to know what they are doing,,,
Edited by steve(ill) - 27 Aug 2022 at 3:08pm
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 1:28pm
Military spec engine. Will likely have to get the number from the old cartridge. Not the same as any tractor with the 3500 engine
Fox & Ginn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fox & Ginn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2022 at 10:48am
cartridge filters / cans .  Its like the green unit  in the 2nd photo
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2022 at 8:34am
same as 210-220 and 7030-7045 tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2022 at 7:45am
do you have spin on filters, or cartridges that fit inside a can...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fox & Ginn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2022 at 6:54am
We have a Allis Chalmers generator set, engine model 3500-A;   S/N # 3D-67128
We're trying to determine the correct oil and fuel filters for it.    Didn't see part #'s in the manual we found online..      Suggestions ?    thank you
