Gemmer box?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Gemmer box?
    Posted: 28 Jan 2017 at 10:24pm
Can anyone clarify if these are Gemmer steering boxes. I have couple of these and someone needing one. Also, are Gemmer boxes better than Ross or are they about the same. Anything special about them? I've never been in a Gemmer box. Rebuilt several Ross boxes.
Edited by AJ - 28 Jan 2017 at 10:28pm
Can't fix stupid
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2017 at 10:37pm
I don't know the difference either. Would be interesting to know the differences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 5:33am
The Gemmer boxes are a better and stronger designed steering box. The simple way to tell the difference is to remove the drag link arm. The Ross has even splines all the way around, the Gemmer box has 4 wide splines at every 90 degrees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 8:18am
you can look at the side of the gearbox, thru the tool box hole and tell the difference. Dick had some photos on his web page.. The ROSS uses a single pin running aginst a worm gear to turn the wheels..... The GEEMER uses a couple gear teeth running aginst the worm gear to turn the wheels.. harder to wear out two TEETH compared to one PIN.. you also have to know if the box is for a B, C, or CA... there are differences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 8:19am
With CREDIT to DIck........... here is his web page for GEEMER.
