Gehl Skidloader Quick attach |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1867 |
Topic: Gehl Skidloader Quick attachPosted: 29 Apr 2016 at 11:15am |
I'd like to build some attachments for my gehl 4610 skidloader and was wondering if anybody had drawings for the hitch that needs to be welded onto the attachment.
Thanks David
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 29 Apr 2016 at 1:57pm |
Is it not the standard skid steer hookup? you can buy blank plates to build whatever you want
coggonobrien
Posted: 29 Apr 2016 at 1:58pm |
i believe it's a standard universal, I just don't want to pay 400-600 for something I can draw and burn out with the laser at work.
CAL(KS)
Posted: 29 Apr 2016 at 2:08pm |
here you go, i think this is what you are looking for
Edited by CAL(KS) - 29 Apr 2016 at 2:15pm |
coggonobrien
Posted: 29 Apr 2016 at 2:16pm |
no, it looks more like the hooked side of this
http://www.ebay.com/itm/Wheel-Loader-Skidsteer-Quick-Attach-Adapter-Case-Cat-Deere-Gehl-JCB-Kubota-Terex-/281833877553?hash=item419e9bb031 |
CAL(KS)
Posted: 29 Apr 2016 at 2:23pm |
ok so you need to fashion the male part that attaches the loader and cylinder rods to fit the standard skid steer plate?
Edited by CAL(KS) - 29 Apr 2016 at 2:25pm |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 29 Apr 2016 at 2:37pm |
If you want the tractor side I think that is custom to each type of tractor. When I converted my d15 I had to have it custom made. The bucket side and the small plates that slide into the bucket side with the pins are pretty cheap on ebay but you have to build the part that mates to the tractor. I need to have mine redone because it didn't curl the bucket up enough and doesn't currently get the full travel of the cylinders. Take the time to mock it up with a wooden template it will prove to be time we'll spent. I made a temple that allowed the curl cylinders to go full travel while not allowing the cylinder ram to run into the lower support pin. I had to change the distance between the two pins to get that right then I changed the front angle of the plate to get the bucket to curl up more when down and still have a good dump angle when up. That is a balancing act with an old tractor that doesn't have a self leveling boom. There is an older thread here I think I put quick hitch or something like that in the title discussing the troubles I had with that last fall.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54687 |
Posted: 29 Apr 2016 at 5:54pm |
You have the tractor. Why not just make a mock-up jig, out of wood, for the male half, that goes on the tractor? That's the route that I used to make the 15 attachments that I cobbled up to fit my ASV RC-30...
coggonobrien
Posted: 30 Apr 2016 at 1:53pm |
DIYDave, that's what I'm probably going to end up doing, I just thought if somebody already had it, why reinvent the wheel. I'll post of the dimensions when I'm done
coggonobrien
Posted: 03 May 2016 at 7:23am |
Dan73
Posted: 03 May 2016 at 7:27am |
I think that is a European #2 hitch. Something like that it is almost the same thing that is on my case 5240 quickie loader. I just remembered when I looked it up it was European.
coggonobrien
coggonobrien
Posted: 05 May 2016 at 7:23am |
DiyDave
Posted: 05 May 2016 at 5:53pm |
I saw a place in a logging magazine, that I get (forget the name...) that sells the flat weld on plates for just about any machine. If they are plasma cut, they will be stronger. If I can find the ad, I will get it on this forum...
coggonobrien
Posted: 05 May 2016 at 6:07pm |
Everything I'm cutting is eady by laser or plasma table
coggonobrien
Posted: 06 May 2016 at 7:04am |
DiyDave
Posted: 06 May 2016 at 5:39pm |
Found the ad, magazine is part of lumbermen on line group. Phone # is 513-678-1597. No prices listed...
burrows2155
Joined: 26 Dec 2018 Location: annville Pa Points: 1 |
Posted: 26 Dec 2018 at 4:00pm |
how did your mounts for your 4610 turn out. would you be willing to make a couple sets and sell me thank you
coggonobrien
Posted: 27 Dec 2018 at 8:19am |
Turned out decent, I can get pictures sometime. They won't be for sale but I can provide dxf files to anybody that has access to a burn table.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42086 |
Posted: 29 Dec 2018 at 5:28pm |
Son makes skid loadr attachments and has made attachments for small utility tractors also - the face plates are now close to universal on new machines - yet some mfg still have differences so they are not universal fit without some changes .
He also does attachments for Dingo and other such small walk behind , ride on , units used in construction and landscaping work. He is now making a order for a East coast dealer of 10 snowplow units . Follow up is a order for marker installer for Alaskan oil field roads https://koeckeritzironandsteel.com/index.html |
fordrudy
Posted: 11 Oct 2020 at 8:29pm |
hi i recently purchased a gehl4610and want to make a quick hitch for it do u still have the drawings for the pieces you made ? thanks josh
