Gearing down Wd45?
Toddm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddm Quote  Post ReplyReply Direct Link To This Post Topic: Gearing down Wd45?
    Posted: 28 Oct 2012 at 1:08pm
Started pulling this year and learned alot.  We have a Wd45 with a d17 motor in it.   We have more power than what we can put down now.  We can slow it down to idle and still spin out.  so we want to gear down this wd 45 to run 15/5/38 and keep ground speed the same or slower than 16/9/28.  Needs to say at or under 3mph for the speed limit.  Thanks
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 1:46pm
Toddm, we're in the same boat with ours. We've come up with a 45 diesel rear end that should slow downthe mph but I have'nt researched just how much slower. It will be a winter project. Hopefully someone will post some info on this.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 4:32pm
   I run a wd45 diesel rear end and 15.5-38 tires. at stock rpms I'm 3 mph or less pulling.
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 6:26pm
if you research older posts, that may help. Getting ready to change ring and pinion on my 45 with a d 17 series 1 tractor.
This page was generated in 0.075 seconds.
