Gear slides coming out of alignment |
Post Reply |
WD45Canuck
Bronze Level Joined: 20 Jan 2021 Location: Cornwall Ontari Points: 9 |
Posted: 22 Jan 2021 at 6:05am |
Is there a fix to keep the gear linkage from coming out of alignment on the WD45. I often have to take the gear lever out and use a screw driver to realign the gear slides
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4760 |
This is a very common problem on the WD45. The problem is that the "ball" at the bottom of the lever has worn.
There are several "fixes". Some build the lever back up to standard size. Some buy a new lever. There are also oversize pins (that go in the side of the lever) available that may help. Welcome to the forum ! I am just across the border from you. Please stop in and say hi when we can easily cross the border again !
Orange Level Access Joined: 12 Sep 2009 Points: 20946 |
There are four places of wear: #1. the gearshift ball tip on the end. #2. The gearshift/shift cover ball socket. #3. The square alignment pin(s). #4. All the shifting lugs down inside.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3841 |
Sugarmaker did a great project thread refurbing a WD45 shifter. I went through the one on my wide front last year, glad I did! I'll dig around a bit and see if I can find it. Edit; Found it, https://www.allischalmers.com/forum/wd45-shift-tower-details-picture-heavy_topic169724.html?KW=
Edited by IBWD MIke - 22 Jan 2021 at 8:43am |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8332 |
The Dr is right on the money. Fixing any one of these 4 may solve the issue, But To really find out the root of the problem you need to take the shift unit off the tractor and check out all of the areas he mentions. I had a bad one and was able to repair all of the areas he mentions with a Mig welder air grinder, and files. Most of the problem is just wear.
I do have a bunch of pictures on here on the WD45 thread. Also a good service manual will really help too. There are some tricks. Like dont let the spring loaded detent balls hit you in the eye! :) Also best to try to have the tractor transmission in second gear IIRC when you remove the tower. Once I had mine repaired I am pretty confident it will be good for another 60 years. some random shots: mounting to engine stand helped a lot: All of the areas where the shift lever interacted with the shift forks was examined and repaired to bring back to a nice sliding fit. I also built two custom side pins for the slots in the ball. And drilled through the other side of the tower to add a second pin in the ball groove. This is the reverse lock out: Mine was very worn, the tab was broken off and needed welded in several areas cross pin, dont loose that! Stops the chance of getting in two gears at the same time. Spring loaded detent ball in out position. Has to be pushed down lower than the shift rail to be inserted. Hold your mouth just right for this and wear safety glasses. end of my shift rod needed several weld and grind and fit operations. Yes could have bought a new one. Too cheap! pointing at worn areas to be welded and worked over: As mentioned I am cheap. The tower socket was very worn. This allowed the ball and lever to drop too low. The fix. Weld several places on the ball and shorten the end of the shift lever a tad. example of new fit of lever to reverse yoke. After using this on the tractor it must be like when new? Very crisp and tight. Hope this helps! Regards, Chris Edited by Sugarmaker - 05 Mar 2021 at 7:50pm |
sadmyentist
Bronze Level Joined: 19 Jan 2018 Location: WI Points: 100 |
Sorry for the thread necro. Where did you get replacement welch plugs? I got 3/4" from mcmaster and they're a tad too small and won't seat. Thanks
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 82804 |
welch plugs come in standard sizes.. you can not buy one "just a little bit bigger"... If the hole i worn somewhat, i think i would flip the plug over and pound on the cave side with a ball peen hammer and try to mushroom it out a few thousandths bigger... then install ???
sadmyentist
Might be technique....I got one to seat
sadmyentist
Damn that's what I thought. I'll figure something out. There's always RTV.
Post Reply | |
