gear reduction box |
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Topic: gear reduction boxPosted: 08 Dec 2025 at 11:54am |
I have a complete WC Hi-Crop rear end with the 6.6:1 ratio that I might consider selling. This is the same ratio as an RC.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 05 Dec 2025 at 9:48am |
don t see any shermans around or i would have it allready plenty for 9n fords
Phil48ACWC
Posted: 05 Dec 2025 at 5:00am |
My '48 WC has a Sherman Underdrive either from AC or the original Dealer. High range is 1:1 and Low range is 1.4:1.
Edited by Phil48ACWC - 05 Dec 2025 at 5:01am |
HudCo
Posted: 04 Dec 2025 at 1:02pm |
wondering about taking some gears and shafts out of awd trans and seeing what icould come up with and fab a case for them
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 04 Dec 2025 at 1:00pm |
Yes: There was an aftermarket 2 speed that was either overdrive on underdrive. The underdrive is just want you're looking for if you've gone to big tall tires and don't have the power for them.
Find a set of tires that will work for what little power you have and you'll do just as well in the long run. I've encountered many that swear that to beat those with tall tires, you must also have tall tires. I call BULL$HIT on that. You MUST have tires that work with your available HP, Gear ratio, Balance and track conditions. I pulled a CA for nearly 30 years and could consistently beat Oliver 66s and Farmall C/SuC and Case VACs with my 24" tires. Unless you're pulling on the same track with the same weather condition and same preparation each time it will take a lot of track reading and different size tires to find something that works, but after you do all the clubs will start changing the rules on you like they did to me.
HudCo
Posted: 04 Dec 2025 at 12:50pm |
while i am continuing my search for some low gears for my 37wc has anyone fabricated a gearbox to go were the lift shaft gear box is
