Gear manufacturing
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: Gear manufacturing
    Posted: 15 Jun 2015 at 9:20pm
Wanting a set of gears made! Anyone recommend a good builder for trans gears??
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:53pm
may be someone already doing trans gears for pulling but we had a drop box input shaft gear made for one of our 8550's here.  hollow stub shaft,  splined with a helical gear
in Kansas City
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 5:29pm
Thanks I'll give that a shot.... I've made a lot of calls and if it ain't red or green its pretty much SEE YA .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 6:37pm
Whenever we needed something that wasn't available off the shelf, we used these guys. We cut a blank for them and the bosses Dad or somebody would drive it down. They call back when it's done. Usually pretty quick turn around and never had a problem matching up to other gears.  http://www.southsidemachine.net/
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 7:57pm
how about Ken in Michigan?
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 10:15pm
I have talked to the guys at atlas. Seem pretty sharp but from what i have heard you better not be in any hurry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 8:06pm
Called atlas and no trouble to make a set for 3rd gear spot. Just need to locate original set of gears and ship the to atlas for a pattern. Now searching tractor junk yards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 8:14pm
Now the big question is how much over????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 10:24pm
If you're thinking of making 3rd gear faster than 4th gear direct, you cannot. The only way to do that, is to change the input shaft/gear and the front countershaft gear to speed up the total transmission. So, you need four new custom gears made, if you want 3rd to be faster than 4th.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2015 at 8:14am
Dr. That's some bad news right there!!!! Yes atlas said to count input gears teeth and diameters to see if one set has clearance.
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2015 at 9:41pm
So a guy could send the third gears out to those people and get the reduction between first and second?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2015 at 10:38pm
The OEM input gears on a 180 - 200 are 19 driver and 35 driven. Theoretically to get a gear equal to direct drive you would have to have a 3rd gear pair of 35 driver and 19 driven. To go faster than direct, you would have to have 36 driver and 18 driven for example on the 3rd gear pair using the stock input gears. This would make the 3rd pair driven gear too small in diameter to fit the main pinion shaft. About the smallest tooth count gear you can have in that spot is 21 teeth and that's cutting things close. 22 teeth is safe.
That's what the Doctor is saying. You have to change both input gears (and shaft) and 3rd gear pair (4 gears and one shaft total) to get and increase in speed of close to direct or faster in ANY of the transmission locations. The exception would be installing an overdrive gearbox ahead of the transmission. A possibility would be having only input gears and a shaft made that overdrive the transmission dramatically. I doubt that is possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 9:43am
Due to the major rain, had a lot of time to investigate trying to have 2 Pullin gears. The Dr. brought up a good point and there's no room!!! Having 4 gears made would be the cost of my complete tractor. So the easiest fix would be to change PD driving and countershaft gears and run high range. Lot more room just still only 1 gear. I'm no math wizard but a 0.681 to1 will put me at 25 to 1 and there simple gears, no shift collars ect ect. The problem is I have a regular 7 to 5 job and a family so to be able to keep my hobby all work has to be performed by me. IM A CHEAP OLE BOY!!!! Thanks for this site and its members for all the extra help. I've come a long way sinse its first hook and I can say it's not store bought!!!
This page was generated in 0.199 seconds.
