Gauge Wheel Tire Source? |
K-Mo ![]() Bronze Level ![]() Joined: 09 Feb 2013 Location: Atlantic, IA Points: 91 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jan 2022 at 8:17am |
Looking for a gauge wheel tire source for an Allis G Independent
Gang Cultivator. Same design as the common 4" x 12" gauge wheel tire
except 3" x 8".
Checked with some manufacturers, no can find. Picture is of the common 4" x 12" tire. Any help will be greatly appreciated. K-Mo ![]() |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53235 |
These guys might be able to find it for you...
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8602 |
do you have part number
Good Question. I meant to include it. P/N 317985
Brendan (AB) ![]() Bronze Level ![]() Joined: 19 Sep 2013 Location: Alberta Points: 44 |
If you find a source for those tires, please post it here. I would like to find a set for my cultivators also.
Thanks!
I have considered these as replacement wheels. Make new axle bushings from DOM 3/4" OD x 7/16" ID. If you try that route, let me know how it works out. K-Mo
Still, come monday, give miller a call.
Your first link was non-specific, so I don't know which of the wheels you were considering. You may find on new wheels, that most have a 1-1/2" hole in them, if so, then all you have to do is to find the right bearing, or something close, and bush the bolt... A word on chinese rubber. even new it has a shelf life of about 5 years after exposure to light of day...
Tire 3" x 8" Hub 3/4" x 3" https://carefreewheelandtire.com/ ![]() |
Close, but it looks chinese, to me. See note, above. That hub looks like it has the knock out bearings that are likely 1-1/2" OD. TSC generally has these in other ID (bore) sizes, easy to change it for the right sized bearings...
