Gasoline
jimwithag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Topic: Gasoline
    Posted: 26 Oct 2018 at 9:57pm
I need gas for my 49 ac g. What do I put in it these days. I guess I can’t get leaded gas. I found a station that had regula lead free gasoline that had no e10. Should I use an additive. Should I use high test premium cause they have cleaners. I’ve learned that premiums come also with e10 or no e10? It’s so confusing
Jim Cridge
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 10:05pm
Regular unleaded is fine. No ethanol is a plus! HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 11:42pm
Tks
Jim Cridge
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 6:31am
I use the same as Tracy in everything from the one cylinder two stroke to the modern day 8 cyl guzzler.  Non ethanol is too much of a hassle for me to find and transport, that being said I would always use that if available in things that get little use.
My two lawn machines sit all winter with E10 in them (treated) and fire right up in the spring.
My eldest tractor (1950) spends most of its time under cover in the bard.  It is stored defueled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 8:36am
Tks for the reply dave, good point, it is hard to find
Jim Cridge
Bob J Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 8:50am
I only use premium no ethanol  in everything, from lawn mowers to
tractors with Sta-bil in the tank for storage.
I had nothing but problems trying to use regular with E10.
Using premium  no E10 has made a big difference.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 9:23am
I just put three gallons of 87 no ethanol in my Geri Can. :) I mixed 2.5 ounces of StaBil with it. This is to feed my snow blower through the winter. Last year when I did this I had enough left over to run my lawn mower all summer, right up until last weekend. With that year old gasoline, I never had any problems. The mower always started on the first pull.
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 11:23am
i used to use stabil but i did some research on long term fuel stabilizers and found that stabil doesnt do a very good job with the ethanol fuel,,,
i wanted long term stabilization,,,,because my gasoline tank only gets new fuel when it is empty,,,about every 2 years,,,,and i use that gasoline for everything ,,,mowers chain saws,,and my 170 gas,,,,they all sit a lot,,,until needed
i found a product called PRI-G,,,,they also make PRI-D,,,, one for gas and one for diesel,,,and they claim it will stabilize the ethanol in the fuel too,,,so i started using it about 5 years ago,,,,never had any trouble with the stored fuel,,,,it is always fresh,,,,i just had gasoline put in the tank a month ago,,,treated it with PRI-G when it was put in,,,,last load of gasoline had been in the tank for two and a half years,,,,,not one speck of a problem,,,,
just my opinion,,, but,,, i think PRI  is better than stabil,,,it cost more but you use less per gallon,,so it may be cheaper in the long run,,,BUT you cant find it at walmart,,,not sure about parts stores,,,,i get it on line when i need it,,,,for me i wont go back to stabil,,,,,PRI-G or D for me,,,all the time in all stored fuel
my .02
ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 12:08pm
StaBil claims to work in E10. The usual dose is a half an once per gallon. It's hard to use less when I'm making 2 or 3 gallons.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 12:56pm
I've used PRI-G  for the last 2-3 years and have had no problems.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 1:35pm
I don't use anything bUT E15 in everything. Not a problem with anything. I Dont use additives, except 2 cycle oil for the chain saw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 2:09pm
Corrosion can be more of a problem with E15 if your vehicle isn't Flex Fuel. That won't show up right away. Give it 4 or 5 years and see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 2:33pm
Tks folks for the good responses
Jim Cridge
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 7:43pm
Jim-  You noted 'leaded fuel'... it's a very common misnomer that antique cars and tractors somehow 'need' leaded fuel.  I've had guys tell me I'm gonna ruin my '24 Model T and '29 Model T Fords on regular pump gas, but they're wrong-  TEL was 'available' but only in select circumstances, as early as 1923, but it saw no substantial proliferation of use until midway through WW2, in high altitude supercharged piston aircraft engines.  After the war ended, it became much more common in automobile fueling stations... but it wasn't a 'necessary thing'.
It only BECAME necessary after automotive manufacturers realized that they could skimp on production, by just relying on requiring leaded fuel, and as such, it is really only necessary in SOME automotive engines- particularly two categories: low grade engines (ones that don't use hardened valve inserts) and high-compression ones that wouldn't run full-advance or full horsepower, or high altitude... without it.
Your tractor's engine is an INDUSTRIAL engine- not only was it designed to not need tetraethyl lead, it doesn't even need GASOLINE... they were designed to run on a myriad of fuels, and factory available with PROPANE for mobile... and would burn natural gas in stationary applications as well.  There's no adding TEL to Propane and NG.
This is same for ALL industrial engines-  if they're true industrials, the valve seats and valves are absolutely FINE without TEL.
Ethanol 10 is fine, but only as long as you pour it in, and run it through.  Don't leave it sit in storage- Ethanol does not 'mix' with petroleum, it merely stays in 'suspension'... so the alcohol 'settles' to the bottom of the tank.  It's also very hygroscopic- it's a dessicant- absorbs moisture from the air, and from surrounding fuel, and collects it at the bottom, where the mixture corrodes dissimilar metals in your carbeurator, fuel line, sediment bowl and tank, and when you go to start it, you get straight water, then saturated alcohol, before getting any gasoline.  For long term, either run it dry, or use regular non-ethanol.  When you go for spring startup, dump all the 'storage' fuel into a separate can, pour in several gallons of fresh fuel, and get it running.  If the stuff you dumped smells 'sweet', then find some 'other' use for it... the investment you make in time and trouble will be much less than the frustration of a fuel system cleaning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 11:11pm
No E of any type keeps our engines running smooth...despise that stuff...I’m sorry to all the corn farmers. Just my experience. Causes check engine light to come on in older vehicles also due to O2 senser issues. Seafoam cleans them up. Never run the stuff unless I cant find no E fuel.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 7:10am
Does anyone use Sea Foam?
We have 2 stations within 10 miles that sell non-alcohol gasoline. Not a big deal to stop a time or two a year to get 2-3 cans. I have used this for several years in the old tractors that sit a lot and not had any problems, unlike the ethanol gas. Also use in the rototiller. I always shut the gas off and run till they die.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 8:34am
Tks Dave, Ilot of relative history. Gas brands have been quite involved in this. I don’t run my tractor. Much. So it sits in closed shed, especially winters. My age is shutting me down. I still love to start it is and listen to the purrrr
Jim Cridge
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 8:35am
I’ll get on google and study it, tks
Jim Cridge
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 9:12am
Illinois has been on E10 for 30 years. I first started using it in my 1989 F250 when new. Been in EVERYTHING I own since then. 7 small tractors, lawn mower, chains saws, No problems.
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 9:43am
We run 91 Non Oxygenated in everything older or anything that sits for any length of time. Have had both a B and WD with plain unleaded sit 6 months or so under cover and the fuel would separate in both their sediment bowls. Even after dumping the fuel from bowl it would separate again. I think the ethanol content pulls the moisture from the air around it. I have pics but they wont upload.
Edited by wade89 - 28 Oct 2018 at 9:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 9:47am
Read the contents of Seafoam, Isopropyl Alcohol and mineral oil 'Blended Hydrocarbon'.
https://seafoamsales.com/wp-content/uploads/2017/01/Sea-Foam-Motor-Treatment-SDS-v20161205-ENG.pdf
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 11:26am
I use rec fuel in everything but my vehicles. But I don't use my tractors on a daily basis so it doesn't cost me that much overall and they sit for extended periods sometimes. When I bought my wife's atv (2015) I was told not to use seafoam in anything new because it has fine metal particles in that make an engine run hot and everything now is set to run as hot as it could. Machines were being burned up with it. As far as stabil. I understand it would jell ethanol gas. Maybe they changed it now. Most gas now has enough additives in it already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 11:41am
Sea Foam is a cleaner, isn't it? If it's a gasoline stabilizer, I'd like to know.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 12:33pm
E10 in everything from the weedeater to the D17.  Never had an issue related to it's use.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 2:47pm
Seafoam is a cleaner, not a fuel stabilizer. Excellent product. Cleans fuel system, carbs, fuel tank,fuel injection, valves, crankcase if you use it in place of same amount of oil. Really cleans the crank case after only 15 minutes. Pretty shocking when you drain the oil. Even works in diesel fuel.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 3:09pm
I've found most gas stations I've been to in Oklahoma have both ethanol and no ethanol. I sometimes skimp and put e-10 in my pickup, but I only put pure gas in my tractors and other equipment that may sit for a while.
That PRI-G sounds very interesting. I'll have to look it up!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 4:51pm
Pure gas sure makes a difference in mileage in my vehicles.  Can really tell a difference when I plow with my D-17.
I do use e-10 when I am forced.
This page was generated in 0.781 seconds.
