Gasket Question |
Johnwilson_osf
Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 944 |
Topic: Gasket QuestionPosted: 08 Jul 2015 at 8:39pm |
A quick question about gaskets. I just got my new water pump for my F2, and it has a paper type gasket to mate the pump housing to the block. I have worked with people of two different schools of thought.
School 1: put the gasket on, and bolt it down, the bolts will squeeze the gasket material to make the seal. School 2: Always put gasket sealant on the paper gaskets, then tighten. Your thoughts. Thanks in Advance John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
CTuckerNWIL
Posted: 08 Jul 2015 at 8:51pm |
If both surfaces are flat and clean, the gasket should be fine by itself. Might be easier to put a layer of gasket sealer on the pump to hold it in place though. I have a can of permatex forma gasket (don't know what type but it's near black) that comes in real handy for such things, but only use it on one side.
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1561 |
Posted: 08 Jul 2015 at 9:07pm |
I have always put some type of sealer on both sides of any paper gasket. You dont need alot. A thin coat will be enough.
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10021 |
Posted: 08 Jul 2015 at 9:22pm |
Indian Head Shellac works great on paper gaskets.
