Gasket Part Number Help WD45 |
Jeff(WD45-SATX-TN) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Feb 2012 at 1:59pm |
I am trying to verify the correct part numbers for the seal and gasket to replace my belt pully. This would be the seal that goes into the clutch housing. The gasket is between the frame rail and housing. For a 1954 WD45
Are these correct? 70202289 For the belt pully tube to housing seal, 70223574 for the gasket between the frame rail and housing. Thanks in advance for the help. Jeff
1954 WD45 NF "Iron Tater"
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
seal part is correct, not sure on the flange gasket
Bump - Anyone esle have input on the gasket between the frame rail and housing. The parts book has a note for 70223574 - seems for a WD only??
Bruce(IA) ![]() Bronze Level ![]() ![]() Joined: 11 Sep 2009 Location: Vail,IA Points: 84 |
I don't think it needs a gasket, only the round cork seal
The gasket was for the early, bolt-on covers
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
there is no 3 eared gasket for thr phlange...just the cork seal
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8636 |
My WD has a round tin plug in that hole and 1 bolt/washer that catches the edge. Dad bought it new in 49 and that plugs been there as long as I can remember.I'm 56. I've never seen the belt pulley that's in the barn on this tractor.
David(Stockbridge)MI ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Have them in stock...... www.djstractorparts.com David 734-320-3470
70202289
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
